FS: turbo, D16 mani, 3" exhaust, 450 injectors...
3" exhaust. Came off my 98 coupe, will fit other 92-00 Civics with modifications. Mild steel piping with Tsudo N1 style muffler. Some melted plastic on the canister/tip and some small scratches on bottom of canister. 3 bolt flanges. Was patched at one point. Includes gaskets/bolts, no rubber hangers.
$150 picked up
AiResearch/Volvo T3 turbo .48A/R Used, very minimal shaft play. Good candidate for a rebuild. 5-bolt exhaust flange, oil inlet and drain fittings. Hot side has been coated. Comes with ghetto fab downpipe with flex section and O2 bung. $100 picked up
3" cat with uncut air tube. 3 bolt flanges and O2 bung with cap. Some very small scrapes, all material intact. $40 picked up
Braided oil feed line with brass block fitting. 46" long. $15 picked up
eBay cast T3/T4 mani for D15/D16 engines. 2 bolt wastegate flange. Includes new eBay gasket. When I bought this, one of the bolt holes was drilled all the way through. It has been plugged with no issues. $30 picked up
Tuner Toys 450cc injectors. Comes with OBD1 injector clips and pigtails and some extra OEM wire.
$50 picked up
If you want to start a budget boost project, I'll part with all of this stuff as a package for $300 picked up
BLOX JDM header flange. Brand new. $15 picked up
Mainly looking for cash but will trade for high flow cat (2.25" - 2.50"), ASR brace/sway bar for EK chassis, and aftermarket LCAs for EK chassis (F7 or S2 only).
All parts located in Gaithersburg and
available for pickup seven days a week, anytime between 7 AM and 8 PM. Can also meet serious buyers within Montgomery or Fairfax counties depending on day/time/location. I can also ship parts at buyer's expense. PayPal only for out of state transactions.
PM or call/text 703-850-3546 for fastest response
$150 picked up
$50 picked up
hondatuner020
Jan 18, 2017 06:53 AM
