Honda Accord 2001 idle isues
Old Jun 30, 2014 | 08:10 AM
icedstar's Avatar
Default Honda Accord 2001 idle isues
Hi, i came here because i have no idea whats wrong with my car, i have a 2001 accord with a F23A engine and my problem is that in idle it feels like the car was missing ignition in one cylinder and it vibrates a lot like the car was about to stall but it doesn't, i changed the spark plugs and the cables too, i've read that it could be a bad ignition coil but it seems like the problem is on the 3rd cylinder only because when i tested for sparks when i remove the 3rd cylinder cable it keeps doing it just like it was connected, i'm running out of money from buying the parts and i need the car to work so i'm kinda desperate now, hopefully someone knows whats wrong with my car.
Old Jun 30, 2014 | 09:19 AM
fubuallstar's Avatar
Default Re: Honda Accord 2001 idle isues
is check engine light on? is this when the ac is on? adjust the idle using a flat head screw driver. remove the intake tube and right above where the tube connected on engine is a small circle with a flat head screw inside. turn it counterclockwise while idle running. idle should clear up. what rpm are you at anyway? if its running poorly there has to be a check engine light. even if its not on check it. seen alot of our gens with missing check engine light bulbs
Old Jun 30, 2014 | 09:22 AM
pic
Old Jun 30, 2014 | 09:25 AM
icedstar's Avatar
Hi fubuallstar, check engine light is off but it works cuz when i put the key in the starter it lights up before i turn on the car, the problem increments with the AC on but even when its off it still there, i might try the idle thing you said but since the problem keep hapening when driving i dont think that will do the trick but im going to try anyways
Old Jun 30, 2014 | 10:27 AM
afnan's Avatar
If you are experiencing problems at idle and at higher rpm then your third cylider may be loosing compression as you have new wires and spark plugs. Did you changed rotor and cap too? if above were changed then go straight for compression test on all cylinders
Old Jun 30, 2014 | 04:30 PM
icedstar's Avatar
i was thinking about changing those i might do that and come back
thx
Old Jul 3, 2014 | 03:57 PM
icedstar's Avatar
so far i changed the distributor cap and rotor, the spark plugs and the cables, i had the injectors cleaned and its still have the problem, its like a misfire in one of the cylinders when you hear the exhaust it sounds like that and it smells like gasoline.
What could be the cause of this misfire if i already changed pretty much everything?
Old Jul 3, 2014 | 04:32 PM
95accordCE6's Avatar
This is only at idle? Or does it stumble when accelerating too?
Old Jul 4, 2014 | 11:44 AM
icedstar's Avatar
its all the time
bestofthe80s
May 7, 2017 05:21 PM
Donn Qwrty
Engine Management and Tuning
Jul 27, 2016 06:55 AM
Uncle Ben 1
Mar 5, 2013 06:29 AM
accord 2 door
Aug 15, 2011 05:55 PM
ajth87
Mar 9, 2006 01:49 PM
