PLEASE HELP, '93 Accord temp AND fuel gauge not working
Old Jun 29, 2014 | 07:50 PM
Remmick's Avatar
Default PLEASE HELP, '93 Accord temp AND fuel gauge not working
Hi guys, new here and a new honda owner, picked up a nice 93 accord with low mileage the other day but later discovered the temp gauge and fuel gauge doesnt work.
I have done alot of research and searches but can't find what I am looking for.
I know the fuel gauge is stuck at 3/4 because I put the car on a small slope and the low level warning light came on.
I know the temp sender is working, I have tested it by grounding it and it does not go to 'hot', but will always remain at cold. It does how-ever move a TINY bit when i turn the ignition on, it moves down about 1mm (not sure if that is a clue to what might be the problem).
Thermostat is working.
Engine is full of new coolant.
I can't find any fuse specific for those two gauges, but have checked every fuse at the kick panel and engine bay.
Is there a way to test the gauges?
Anyone have any wiring diagrams for the cluster and fuse box so I can start testing with my multi-meter (and any tips on how to do that properly would be much appreciated, I was just going to set it to volts and turn ignition on ground the meter and test the back of the pins, but need to know what is what first - need a diagram )
Any ideas very welcome.
On a side note, does anyone know if the drivers side power window motor shares the same motor with any other hondas?
Thanks in advance!
Remmick.
Old Jun 29, 2014 | 07:54 PM
Remmick's Avatar
Default Re: PLEASE HELP, '93 Accord temp AND fuel gauge not working
At this stage I would most like to know where the gauge terminal on the ignition is.
Old Jun 29, 2014 | 09:36 PM
Remmick's Avatar
Correct that, anyone know which wire it is going into the cluster? I am guessing one of the yellow wires going into the green plug that is closest to the temp gauge on the cluster.
I want to test the voltage
Old Jun 29, 2014 | 11:08 PM
Remmick's Avatar
Ok so I found the diagram and the wires, there is a yellow wire from power going to the gauge, and a black coming from the gauge to ground and a red coming from the sender to the gauge.
Now with the red wire connected to earth and ignition 'on' testing the voltage of the wires going into the cluster i get full voltage with yellow, no voltage with the red and a chagne from 0 to 0.03 volt when testing the black.
sound like the gauge is fried?
Or possibly an open in the red wire circuit?
Old Jun 29, 2014 | 11:51 PM
Remmick's Avatar
Final update for today, I connected a wire directly to the red wire going into the cluster and earthed it, the gauge did not move (essentially this is testing if there is a problem with the red wire to the sender).
So pretty much answered my own question in this thread, I will try replace the cluster, unless anyone else has any other thoughts?
Can I replace the circuit board and not the whole cluster? Basically so I dont change the actual mileage readout.
And again, does anyone know if the accords driver side power window motor shares the same motor with any other hondas?
alex lyndon
Nov 12, 2017 03:41 PM
bdmlilburn
Nov 5, 2011 07:37 PM
night
Mar 2, 2011 09:55 AM
Tipsy86
Aug 11, 2010 09:10 PM
armharm
Oct 22, 2002 03:04 PM
