s2s1 b18cr
Old Jun 28, 2014 | 05:59 PM
kulo's Avatar
Default s2s1 b18cr
Looking to get s2s1 for my b18cr
do i need to upgrade injectors
will get rdx and walbro 190/5
Old Jun 29, 2014 | 06:56 AM
blackeg's Avatar
Default Re: s2s1 b18cr
injectors i would upgrade, but i dont think the fuel pump is necessary.
check out this link its cool and helpful
http://www.rceng.com/technical.aspx?...JwJPlAF1sCF5ld
Old Jun 30, 2014 | 08:12 AM
93egSLEEPER's Avatar
Just curious as to why you chose those cams.
I would do a set of RDX injectors and a walbro w/ adjustable FPR as the RDX's tend to like a base FP of around 50psi. There is power to be had in the fuel system alone.
Old Jun 30, 2014 | 09:01 AM
EpHatchy's Avatar
stage 1 as in tuner 1? or pro1 ? tuner 1 cams are pretty much the same came in the stock R.fyi
Old Jul 1, 2014 | 04:42 PM
soaringchimp's Avatar
Don't change injectors unless you have engine management. Without engine management increasing fuel pressure would be a better idea.
If you have GSR cams, S2S1 are a nice upgrade. If you have ITR cams, there are gains to be had, but the delta is not as great.
amorasem1
Engine Management and Tuning
10
Dec 28, 2012 09:17 AM
chadleehonda
Dec 17, 2010 01:02 PM
redline760
Apr 4, 2008 12:37 PM
type_r_jon
Mar 15, 2006 01:08 PM
ice11honda
Jun 19, 2005 06:55 PM
