Help im confused as f*** what dizzy do i use? Obd0 to obd1 swap
Old Jun 27, 2014 | 06:20 PM
jacoblytle's Avatar
Default Help im confused as f*** what dizzy do i use? Obd0 to obd1 swap
Have a 1990 integra b18a1 and I'm getting parts for an obd1 conversion but I don't know what distributer to get. Iv got the jumper harness, p74 ecu, 4 wire o2 and I bought pre-made distributer jumper harnesses to make it look good. And also do I use the stock plug wires?
Old Jun 27, 2014 | 08:29 PM
m4xwellmurd3r's Avatar
Use a nonvtec obd1 distributor. Stock wires are fine
Old Jun 27, 2014 | 10:06 PM
jacoblytle's Avatar
Will I need an adapter? What year car should I get one from 92-93 non vtec integra?
Old Jun 27, 2014 | 10:11 PM
You need the obd0 to obd1 jumper harness for the distributor, and any non vtec obd1 from 1992-1995 integra
Old Jun 28, 2014 | 04:13 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Help im confused as f*** what dizzy do i use? Obd0 to obd1 swap
Just to add you could also use any 96-01 integra b18b distributor or 97-01 b20 distributor with an obd0-2 adapter as well.
Old Jun 28, 2014 | 06:34 AM
jacoblytle's Avatar
Big thanks!! I can finish the conversion now!! What o2 sensor do I use? Any 4 wire honda one?
Old Jun 28, 2014 | 08:09 AM
Yeah, but depending on what converion harness you have, you might have to wire it up on your own. I know rywire sells a kit that comes with the o2 harness pre made.
white92teg
Feb 12, 2010 01:09 PM
Faya
Engine Management and Tuning
Feb 16, 2009 07:40 PM
TurboAngst
Dec 2, 2007 10:29 AM
alexsracing
Nov 14, 2004 01:37 PM
Norcalstoppy
Jul 13, 2002 08:02 AM
