'95 Pass. Seat Back Lever Knob Removal?
Old Jun 27, 2014 | 08:07 AM
forward's Avatar
Default '95 Pass. Seat Back Lever **** Removal?
How does one remove the seat back release lever ****(?) on a '95 Accord wagon/sedan seat? It doesn't appear the **** can slide through the side cover's slot and I'm not sure how the **** is retained to the metal lever inside it.
Here's the **** in question:
Old Jun 27, 2014 | 08:13 AM
NerfGunner420's Avatar
Default Re: '95 Pass. Seat Back Lever **** Removal?
ah this silly thing. you have to pull hard away from the seat, be careful i broke one trying it to fast i suggest you put some wd40 or pb blaster to help it slide better and loosen the grime that has accumulated thru out the years
Old Jun 27, 2014 | 09:18 AM
forward's Avatar
Thanks. I found you need to flex/stretch the slot in the side cover slightly to allow it to slip over the lever ****, but the side cover came off without any trouble.
hamadiscool
Jul 3, 2006 11:49 PM
dc2r01
May 25, 2006 12:42 PM
torq97teg
Mar 31, 2005 02:56 PM
TTWS6.
Aug 7, 2003 09:45 PM
Acura_I-RS
Mar 29, 2003 07:28 AM
