suspension help-question
Old Jun 27, 2014 | 04:36 AM
hodrod's Avatar
Default suspension help-question
Have a 95 ex sedan. Need to know if front suspension from prelude of same year or front suspension from 98-2000 accord will interchange.
Old Jun 27, 2014 | 05:51 PM
95accordCE6's Avatar
Default Re: suspension help-question
If you don't mind me asking, why do you want to use suspension parts from either of those cars and which parts in specific were you referring to? If I remember correctly the 98-02 spindles/hubs can be used for a 5 lug conversion and to eliminate the trapped rotor setup. I'm also assuming your accord has an f series engine rather than the c series, relevant since suspension components vary between the i4 and v6 models
Old Jun 27, 2014 | 07:59 PM
hodrod's Avatar
Specifically the spindle, hub, rotor and calipers. My car is a 4 and yes the encapsulated rotors are a pain. Eventually I would like to upgrade the brake system but cant do so as of now. The car is a daily driver and stock honda parts are easier for me to come by than aftermarket. Also if changing the spindle and hubs do the drive axles have to be changed?
Old Jun 27, 2014 | 10:02 PM
fubuallstar's Avatar
probably can use the same. best thing is to go to a junk yard and take some measurements. you need to check width of hub(spindle) and rotor the splines should be the same. BUT if it were me i would leave it alone. It might just be a death trap after you convert. get good name brand rotors and quality pads, press bearing back in or i done it with hammers but a pain in the ***. the swap wont be bolt on and not worth the time. No need to upgrade brakes further good pads and rotors will do a great job no matter how you drive. best brakes are your tires so invest there lol
Old Jun 27, 2014 | 11:05 PM
MAD_MIKE's Avatar
MM Gruppe B
Pretty sure you can get away with using the complete 2.3 knuckle with little worry.
Avoid the Prelude, it uses a larger LBJ and IIRC the stub axle is a larger spline... for the ladies.
edimonster
Jul 6, 2010 07:21 PM
