1997 Civic HX EGR Woes.
Hey guys, I've got a fun one for you today.
I have had this check engine light on for quite some time now and no matter what I do I can't seem to permanently shake it.
First off, my Civic has 258,000 miles and has had a pretty tough life. I first got the check engine light on my previous original engine. The first symptom was that under load (70%+) the engine would make really loud pinging noises. That's when the check engine light came on telling me that I had EGR low flow (P0401). It was this and the combination of a couple other things that made me get angry enough at it to just replace the engine. Turns out the replacement engine had the wrong intake for CA smog so I had to reuse the old intake manifold and the problem came right back on a 60,000km Japanese engine.
Okay, so that narrows it down to the intake manifold - so I tried replacing the EGR with a known good used one that I had in another Civic - no dice. I took off the EGR plate, cleaned the heck out of it (Was super crammed full of carbon) and then cleaned all four ports with a .22 bore brush. I kept cleaning until it stopped coming out with crud on it.. Still no dice.
I gave up and took it to a mechanic. He suggested that the Catalytic converter was plugged up causing backpressure in the system and causing the EGR to misread. Replaced the cat with an entirely brand new one (The guys at the exhaust shop told me the one I replaced was not clogged and showed me with a flashlight.. Doh) That didn't help either.
The only thing I have left to replace is the entire intake manifold and I really don't think I can source a manual 97 Civic HX CA legal intake for very cheap.
Also, I think I need to stop taking my car to this mechanic, he is most likely stumped and shooting in the dark which is going to kill my wallet.
As a note: the pinging problem goes away if I put 91 octane gas into the car and then put additives in.
Yesterday I shoved a big metal pipe cleaner into the exhaust port and ran it around a bit and wasn't able to really pick up any extra crud. Cleared the code, and then got it back again last night coasting down a hill with my foot off the gas in gear.
Thanks in advance, I really need your guys' help.
I followed this guide: http://www.tegger.com/hondafaq/egr-fix/
Something about going down a hill with my foot off the gas and using compression braking can guarantee that the CEL is going to come back. Does that help anyone?
Also, using higher octane fuel prevents the pinging noise from happening, not quite sure if it stops the CEL from coming back, I might go put 91 with booster in it next tank and see if I can keep the code from coming back. If it does, does that provide any extra help?
I don't know how much deeper I can clean:
https://i.imgur.com/SNoxd2W.jpg
https://i.imgur.com/OkNYsCj.jpg
And the intake side will suck a towel in there's so much of a vacuum leak.
What about the other passage ways. If you look behind the injectors because there's a plate that leads to the egr that you need to clean as well.
Okay, I'll order another EGR valve then because I've cleaned everything in the system and the valve itself must be faulty. My mechanic must have lied to me when he told me that he was able to open it with 12V hooked up to it.
In the images it shows the egr valve opening. One leads to the cylinders, one leads to the cylinders. The passage leading to the cylinder has a tiny hole, did you clean in there?
I ran the car with the EGR off but plugged in. I tested to make sure that there is vacuum by holding a microfiber towel next to the hole - it sucked it into the towel.
Also, the car ran like this with the EGR off - I've been reading around and supposedly the car should stall with it off?
Pictures of the underside of the EGR.
https://i.imgur.com/DhA5rYx.jpg
https://i.imgur.com/SUvzQz4.jpg
Do you know of a place where I can jump 12v safely to move the solenoid in and out? My mechanic that I took it to said that the solenoid on it was functioning fine but I don't know how much I can trust from him.
That's the main reason why I ask you to take a picture of the plug. How am I to determine if it's vacuum driven or electric?
I pulled off the EGR again today and ran some irrigation tubing down the line that leads into the combustion chamber then hooked that up to a can of carb cleaner and sprayed more down the hole and then used a chopped up coat hanger to try and scrape out any extra stuff. I managed to get more carbon, but the engine still pings under load which means it's probably just a matter of time until the 0401 is back.
It's the five speed.
