Rechecking my research
Old Jun 23, 2014 | 10:08 PM
ALDJ253's Avatar
Default Rechecking my research
I have a F22B2 Engine in my 1994 Honda Accord LX. I recently changed the Spark Plugs, however the lower O-Rings under the Rocker Arm are bad. I am going to replace those seals soon, and want to know if I can re-use the spark plugs if they have a little oil on them. I am pretty sure I can clean them and retorque them when the shop is finished correct? Will I have to torque them a few pounds more than the 13 Ft.LBs. that they are put in t brand new?
Also, the Rocker arm Assembly:
12mm Bolt: 15 Ft.Lbs yes?
10mm Bolts: 9 Ft.Lbs?
And does anyone have the Bolt pattern (Rocker Arm Assembly) for the F22B2?
I am sorry, I know this is a lot to read, but before I do the job, I want to make sure this is all Correct.
James Howell
Mar 6, 2018 07:33 PM
mynameizstitch
Jun 22, 2009 08:32 PM
irishgod247
Mar 31, 2007 10:15 PM
Opheleum
Mar 2, 2006 01:37 PM
wessieball
Aug 9, 2002 10:16 AM
