PORTED H22 HEAD SUPERTECH VALVE GUIDES
Old Jun 22, 2014 | 10:01 AM
1991_crxsi's Avatar
Default PORTED H22 HEAD SUPERTECH VALVE GUIDES
Here is my ported H22 Head. I am moving on to a CNC RLZ or 4 Piston head and therefore do not need this anymore.
I tried to take detailed pics for you, but if you have any questions feel free to ask. It has mildly polished combustion chambers, Super Tech Bronze Valve guides, OEM intake valves, exhaust valves (4 OEM and 4 aftermarket replacement), valve seals (not yet installed), rocker assembly, OEM valve springs, OEM retainers, OEM keepers, OEM shims (which need to be reamed if you want to fit over the Supertech guides), cam caps, new oil orifices, and bolts. The head has been decked just enough to assure a flat surface and has zero miles on it since the machine shop did the valve job.
Most of the port work is focused on the intake ports, while the exhaust ports just had the casting flaws removed and the bowls blended.
I can also include a set of JDM H22 cams and cam gears upon request.
Ideally I would like to get an H22 head on trade as a core (So I can send that to CNC) with $500 on top, but I am open to all offers.
Also I am interested in some Skunk2 Pro1 cams so send me your offers!
Old Jul 17, 2014 | 06:12 AM
1991_crxsi's Avatar
Default Re: PORTED H22 HEAD SUPERTECH VALVE GUIDES
Old Jul 28, 2014 | 02:40 PM
1991_crxsi's Avatar
sooooooo shiny... so fresh.
Old Aug 7, 2014 | 05:21 PM
1991_crxsi's Avatar
Bump up the jam.
Old Aug 10, 2014 | 08:35 AM
1991_crxsi's Avatar
Accepting trades. LMK
bump
Old Jan 22, 2015 | 06:11 AM
1991_crxsi's Avatar
bump
Old Feb 2, 2015 | 04:46 PM
Velocity1's Avatar
Sent you a PM.
gnxpro24
Jul 15, 2014 08:02 PM
Charlie Moua
May 8, 2012 12:54 PM
2mchbst
Dec 16, 2011 02:39 PM
per4mance
Mar 20, 2009 04:18 AM
h23vtec_dc2
Mar 11, 2007 09:42 PM
