B18b1 w/S2 manifold and ITR TB issue.
Old Jun 21, 2014 | 07:54 PM
Marvin1985's Avatar
Default B18b1 w/S2 manifold and ITR TB issue.
Car: 99 civic with ob2 ls swap. On a chipped p28 from phearable.net
Changes: just installed a S2 manifold and an ITR throttle body.
Issue: after bleeding out the system I have a steady idle at 1000-1200 rpms. How should I go about adjusting my idle properly?
Also I had to ghetto my p75 throttle cable bracket to make it work. Is there any bracket that'll work right? Or do I have to make one?
Old Jun 22, 2014 | 12:44 AM
tony_2018's Avatar
Fish Twig
Default Re: B18b1 w/S2 manifold and ITR TB issue.
Are you asking if adjusting the idle is any different when your intake manifold was stock, no its the same. If the s2 was a stock replacement than you shouldn't have to do anything but install.
Old Jun 22, 2014 | 09:40 AM
Marvin1985's Avatar
I was asking on the proper way to adjust idle but I've found it online. So last issue is the throttle cable bracket.
Old Jun 22, 2014 | 02:02 PM
Marvin1985's Avatar
Well after going through procedure it still won't go down past 900-1000 rpms. That's the best I got it. So close and it's pissing me off. Idle screw on TB all the way in. Checked rotor screw to make sure it wasn't leaving throttle plate open. Tried plugging additional ports on manifold (Pcv valve port) while leaving the pcv open. Nothing has worked fully.
Old Jun 22, 2014 | 06:55 PM
Former User's Avatar
Maybe the throttle cable is too tight, holding the throttle plate slightly open.
Old Jun 22, 2014 | 07:29 PM
Marvin1985's Avatar
I can grab the cable and move it up and down about an inch.
Old Jun 22, 2014 | 07:32 PM
Have you cleaned the TB to see if the throttle plate is sticky?
Old Jun 22, 2014 | 10:07 PM
Marvin1985's Avatar
Yeah everything is minty cleaned. I had adjusted TB too much and plate stuck so I adjusted it back.
Old Jun 22, 2014 | 10:51 PM
MyNamesMatt's Avatar
Have you checked your TPS position? Mine was idling high and running rich because it thought throttle was more open than it actually was.
Old Jun 23, 2014 | 11:09 AM
Marvin1985's Avatar
Tps is stock and untouched. Thanks for the idea though. I'm gonna go over the car again and also take pics.
Old Jun 23, 2014 | 11:11 AM
tony_2018's Avatar
Fish Twig
I'd still check it.
Old Jun 23, 2014 | 11:18 AM
Did you not install your ITR TB? If so, you need to monitor ohms/voltage as you're screwing it in. It will move ever so slightly and throw idle off.
Old Jun 23, 2014 | 11:59 AM
EpHatchy's Avatar
common problem with a stock throttle body and skunk2 manifold is the gasket doesn't completely seal. I bought a gasket from Honda and from oreilys and same problem. the mating surface between the intake and throttle body leaves a small space open between the throttle plate and the iacv port. I had to make my own gasket out of a cereal box. problem went away.
lukasmccracken
Feb 10, 2014 12:00 AM
CRX_RR
15
Sep 21, 2008 05:14 PM
1baddturbosi
Mar 19, 2007 04:06 PM
civic dx
Aug 25, 2004 03:10 PM
dplatt
Jul 14, 2002 09:00 AM
