F20b won't crank need help asap!!
Old Jun 21, 2014 | 05:42 PM
97ludef20b's Avatar
Default F20b won't crank need help asap!!
I just did the f23 crank and rods in my engine and now it won't crank got fire, fuel, and timing is set it just won't start. The car was running before. It had a spun rod bearing and idk why it won't start now. Any help would be greatly appreciated thanks.
Old Jun 21, 2014 | 09:19 PM
Sparksman's Avatar
Default Re: F20b won't crank need help asap!!
Does it spin when you try to start it, or does it do nothing?
Old Jun 22, 2014 | 07:34 AM
97ludef20b's Avatar
Yea it turns over it's gettin spark and fuel I can smell it. It just won't fire up I tried resetting the timming it has crower stage 2 cams also it's also been tuned befor I did the crank swap idk if that has somethin to do with it
Old Jun 22, 2014 | 07:47 AM
97ludef20b's Avatar
It was still running when I took the engine out. I didn't do anything different it just won't start I did a compression test also and it has 210 psi all the way across. I just ain't had so much trouble to get not to crank
prodjay10
Jan 17, 2017 09:12 AM
tonyboii
Audio / Security / Video
Oct 14, 2009 07:03 AM
hollowman8904
Jan 7, 2009 08:59 PM
