What do you think of this damaged turbo?
Old Jun 21, 2014 | 02:32 PM
$MIKE$'s Avatar
Default What do you think of this damaged turbo?
What would cause damage like this? It's a jb garrett
The compressor wheels signicantly hit the compressor housing then locked up and is unable to turn under regular force.
Old Jun 21, 2014 | 02:55 PM
F22Master's Avatar
Default Re: What do you think of this damaged turbo?
Bad thrust bearing? Allowing the wheel to shift forward?
Just a wild guess from someone who knows very little about turbos... lol
Old Jun 21, 2014 | 04:50 PM
civic-steve-94's Avatar
What he said and most likely worn journal bearings time for a rebuild
Old Jun 21, 2014 | 05:05 PM
wantboost's Avatar
Who is Mr Robot?
The compressor housing looks ok, as long as a lot of material isn't gone and there aren't any gouges it should be fine.
it will need a new compressor wheel... and obviously a new bearing system/rebuild kit.
depending on the damage to the turbine shaft, since it locked u and could de damaged/scored or heat checked it might need to be replaced as well.
It looks like one of TheShodans turbos so ask him. until it's disassembled we can't say anything for sure.
Old Jun 21, 2014 | 05:17 PM
$MIKE$'s Avatar
the compressor housing does have significant scoring from the blades. can it be re used?
Old Jun 21, 2014 | 06:52 PM
turbohatch96y7's Avatar
What turbo is it? Looks like a billet wheel?
Old Jun 21, 2014 | 07:16 PM
$MIKE$'s Avatar
Observant u are friend
Old Jun 21, 2014 | 08:08 PM
Ok what turbo is it
Old Jun 21, 2014 | 09:52 PM
KevinEF7's Avatar
Housing definitely looks useable, but I would not buy this turbo if thats what you are inquiring about
Old Jun 21, 2014 | 10:10 PM
Is this it?
Old Jun 21, 2014 | 11:46 PM
NotARaCist's Avatar
I never narc'd on nobody!
Why are we sitting here playing guessing games? OP, answer simple questions, get a simple answer. Keep dragging it out like this, and you're only going to make people disregard you faster.
Old Jun 22, 2014 | 03:25 AM
turbomaniac's Avatar
i agree with wantboost you need a new compressor wheel and new bearings and possible new compressor housing.
if your turbo has ball bearings, you need a new turbo (or new cartridge, compressor wheel and comp housing, that means better get a new turbo)
and aslo i agree this secrecy with your turbo is stupid, they only ask to find out if it is a journal or ball bearing turbo
also with a bearing kit (if it is journal) you can use the same compressor wheel and housing but expect much lower flow. I dont know how much, depends on the housing-wheel clearence.
Old Jun 22, 2014 | 03:33 AM
$MIKE$'s Avatar
If I knew what kind of turbo I would have posted it, in the original post.
My buddy emailed me asking me so i threw it up here to see what you all think.
I just wanted to see if I could confirm the whole thing is toast.
Thanks
Old Jun 22, 2014 | 03:36 AM
good luck at rebuilding it
Old Jun 22, 2014 | 03:42 AM
$MIKE$'s Avatar
He nor I will attempt to rebuild it. What you think this is my first day...
Maybe a little gtx action is in order
Old Jun 22, 2014 | 05:25 AM
thats even better...
Old Jun 22, 2014 | 05:31 AM
$MIKE$'s Avatar
Only problem is the 1900$ price tag.
Old Jun 23, 2014 | 11:13 AM
wantboost's Avatar
Who is Mr Robot?
I've been in touch with TheShodan, we both agree, the turbo isn't totally shot.... It can be repaired.
He'll be contacting you shortly if he hasn't already
shortstopNE
Oct 6, 2014 11:01 PM
1fastsol
Apr 2, 2011 09:40 AM
beboo
Jun 2, 2010 05:17 AM
blackzrd
Apr 25, 2009 03:48 PM
ExVtec
Jun 19, 2004 10:15 AM
