head gasket replacement without removing all of the timing belt
Old Jun 21, 2014 | 04:23 AM
clindberg86's Avatar
Default head gasket replacement without removing all of the timing belt
D16y8 engine. I did a timing job a month ago on my car so I know all is good. Head gasket is starting to leak though...
My question, when I get the upper timing cover off is there anyway to loosen the tensioner pulley through the lower timing cover hole and can I just pop my timing belt off the camshaft sprocket vs taking the lower timing cover off and having to take the whole timing belt off?
Thank you for your time
Old Jun 21, 2014 | 05:23 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: head gasket replacement without removing all of the timing belt
Yes. Just loosen the tensioner bolt, push it aside, re tighten it to lock it in the loose position.
It may be a pain to line everything up again if the belt drops down a bit. You may he better off removing the timing cover. You'll still need to remove the belts and the upper motor mount anyway.
Old Jun 21, 2014 | 05:39 AM
axis11's Avatar
I'm using something like this, no need to remove the lower cover.
http://www.ebay.com/itm/Vintage-Antique-Socket-Style-Wrench-FORD-A-B-Special-Use-615-2-/151319900008?pt=LH_DefaultDomain_0&hash=item233b5e6f68
Old Jun 21, 2014 | 06:48 AM
B serious's Avatar
My procedure is to put a jack on the oil pan, remove both mounts, and lower the engine enough to put a ratchet up in that areas.
The only extra step there is to remove the 2 14mm head bolts that hold the torque mount to the chassis. The rest of the business needs to come off anyway.
You can then jack the motor back up, bolt the torque mount in to support the engine, and go to work on the head gasket.
Old Jun 21, 2014 | 12:18 PM
tony_2018's Avatar
Fish Twig
Hmm, good to know. I didn't pay attention when changing out my timing belt, so for dseries you need to remove the driver side post mount in order to remove the head.
Old Jun 22, 2014 | 02:24 AM
JJT211's Avatar
No need to remove lower timing cover. I actually just finished up a HG change on my y7 yesterday.
I marked the tooth of the timing belt with white out on each side of the timing marks of the camshaft before loosening the tension bolt. When reinstalling, line up cam shaft marks with corresponding white out marks, retension belt, check timing and done!
Old Jun 22, 2014 | 07:47 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
This procedure seems to be only valid on the OBD2x (96+) engines.
On my 95 stock motor I don't see any access to the tensioner without pulling the crank pulley so as to remove the lower cover. I could be missing it but pretty sure on OBD1 motors it's all covered up.
Old Jun 22, 2014 | 08:03 AM
B_Swapped93's Avatar
they all have a little flap that allows for a 14mm socket...can be covered in dirt or never opened but I have yet to see one that didn't. Think about it why would they(Honda) make you remove the whole lower cover just to tighten the belt, it's there just got to look.
Old Jun 22, 2014 | 08:05 AM
Former User's Avatar
You must remove the rubber plug in the lower timing belt cover to gain access to the tensioner bolt.
Old Jun 22, 2014 | 09:09 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Awesome guys, never noticed the plug. And what's funny is I've looked at that diagram I don't know how many times and missed that detail.
I think it's easy to miss when looking from top down due to it being recessed. I will take a closer look next time.
Thanks again!
95LssTeg
May 26, 2006 11:40 PM
trecool44
Feb 3, 2006 05:47 AM
noble4ws
Nov 11, 2003 05:27 AM
obd2gsr
Jan 31, 2003 08:10 AM
