Gas Tank vent line, options?
1998 Civic Hatch
2.0 GSR
I recently purchased a car that has the gas tank vent line venting to atmosphere. They've removed the return line that originally went back up under the hood into the charcoal system.
Any options that I can use, keeping the line at the rear of the car?
2.0 GSR
With the lack of information here are the questions that pop into my head. What is wrong with replacing it with the OEM replacement part? Do you know why they removed it? Did it used to have an EGR system or something? 1998 Civic hatch isn't enough info. What trim level was it? Is it causing any problems that you need it replaced?
Try supplying more information if you want better responses.
spooledhonda
Sep 16, 2007 07:11 PM
