fuel pump won't work/prime, car is stranded!!
Old Jun 19, 2014 | 11:28 AM
B_Swapped93's Avatar
Default fuel pump won't work/prime, car is stranded!!
I was driving along when all of a sudden the car starts loosing power(engine) then it just turned off, check all things like mechanical timing full gas tank the distributor is fine. When I turn the key the engine light comes on and stays on but no prime/click, fuel pressure is at 0 con firmed via a gauge. when I go to start the car it just spins and spins not even a sputter.
pls help
I have a 255 walbro I might try and throw in soon
Old Jun 19, 2014 | 11:51 AM
kaycee_00's Avatar
Default Re: fuel pump won't work/prime, car is stranded!!
You said you were using an s300 right? My friends ecu has those symptoms some times where it'll just erase the map and lock out, solid cel and no priming or anything. Try using a stock ecu or reuploading the map.
Old Jun 19, 2014 | 01:12 PM
wunfstgsr's Avatar
Loved
Community Favorite
check your ecu fuse in the engine bay!
Old Jun 19, 2014 | 04:02 PM
that's what I am using, my good old chipped p30 the s300 got sold
they're both good I'm leaning to wards the damn ECU
Old Jun 19, 2014 | 04:20 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
before you get into the ECU, have you checked for voltage at the actual pump connections, at key on? maby it's just a bad pump? should see a voltage for a second or two when you turn on the key
Old Jun 19, 2014 | 04:29 PM
just installed a new(from the box) walbro 255 still no go have pics of the main relay and ECU to post up.
kaycee_00's Avatar
Oh well if thats the case the ecu is most likely done for. My obd2 p75 did the same thing, I was driving home car sputtered for a few second lost power and had a solid cel. But check the other stuff first and see if you can try a different ecu. You might be able to replace the main capacitor on there and get it working again.
Old Jun 19, 2014 | 04:36 PM
pics: 1st JDM chipped p30 ECU had for over a year now 2nd main relay as I unplugged it not touvhed at all 3rd 2nd part of p30 ecu last main relay again. that last pic looks to show a burn ? can anyone confirm EDIT: tested one lead to the main relay it was getting power(outer side) the other didn't tired jumping the OBD plug SOLID CEL no matter what
Old Jun 19, 2014 | 08:51 PM
minimarine09's Avatar
it could be a bad ground to your pgm-fi main relay maybe? ive done kill switches disrupting the ground and when its not tripped this exact same thing happens, solid cel no matter what, no prime, solid crank but no dice. im no expert but its just a thought
Old Jun 19, 2014 | 08:53 PM
^^^ and like i said, im no expert, but that board looks burnt up to me
Old Jun 19, 2014 | 09:20 PM
the car has no alarm devices at all the grounds are all good and tight/clean from experience solid cel=done ECU but I've had that before and the car still ran(I think). It was a long time ago but I tested one lead to the main relay and it got power on the other side it didn't tho.
Old Jun 20, 2014 | 07:01 AM
fcm's Avatar
fcm
Old Fart
Plug PGM-FI Main Relay in, turn ign. switch on, use jumper to supply a ground to the green/blue lead going to the PGM-FI Main Relay.
If pump turns on, problem is the ECU/ECM, [or connection problem between ECU/ECM and relay. 94
Old Jun 20, 2014 | 02:32 PM
turned out to be the relay and when the relay went it took the SRS fuse with it, I have no clue how those 2 are connected but I've got it going again.
thx guys
JdmRex805
19
Nov 20, 2014 05:23 PM
Rawnee7
Jun 21, 2014 08:28 PM
TimKennard
Jan 2, 2011 10:04 AM
theg35show
Mar 1, 2009 04:15 PM
boosted k20
Apr 14, 2005 01:17 PM
