Not your typical modded Performer X...
Well I decided to do something different with the Edelbrock Performer X intake manifold. Usually when modded, length is taken off the runners to typically work on larger displacement motors or carry power in higher RPM's. Tapering a runner can actually achieve the same effect as physically shortening its length. Obviously only so much can be taken off a casted manifold and lower RPM was still a want in this build.
Here we have an unmolested manifold...
Which was then cut open...
And worked a good amount, notice the bell mouths are widened enough to meet and tapered down...
It definitely needed to be port matched! The other edge of that black line is the floor of the head ports...
Opened up the throttle body to 70MM and welded it back together...
Finished it off nice and shaved, even the freeze plug was shaved. Then wrinkle black it was!
Unfortunately upon installing, a fuel line fitting was bad and sprayed fuel everywhere. So it won't be on the rollers this week, but stay tuned!
Can you post your old chart? Anything else changing besides the IM, and are you coming from a stock ITR?
Those are niiice numbers for an unopened motor.
You can see where it flattens out around 6500, with this manifold it should carry much better, you'll see over 200 for sure. Looks like a really healthy motor.
Interesting work
. This is exactly what I thinking when I made decide between S2 Ultra Street and Performer-X. Because there was so little or nothing information how Ultra Street really perform with n/a B18CR, curiosity win and I went with it.
The dyno chart I posted is with the stock ITR manifold. I'd love to test before and after modding the PX but sadly I don't have those resources. I considered buying another one for this reason, but maybe in the future.
I have a unmolested Performer X I am selling located Tampa, FL area (Not thread jacking just throwing it out there). I switched to the Skunk2 Ultra Street on my car but I am curious to see how this porting does on the dyno!
Nice I'd like to know too. As I have a px right now and look to porting it with the head in the future and like to see the gains
econo box why not just let him borrow it for the sake of dyno testing its not like its gonna break. and it will be a great comparison.
have you dynode your car with PX and skunk2 manifold? I would love to see that dyno also more than anything else to be honest both manifolds seems to be good
I have the wrong manifold for his cylinder head. If anyone was willing to donate dyno time I would be more than happy to run the car back to back with the two different manifolds. I've got a lot going on right now and I can't afford the extra dyno time.
that dip after vtec looks very familiar lol
can anyone explain what its doin there on every Px dyno that I ve seen
I was assuming that it was my cheap ebay exhaust doing its job but his ITR manifold seems to have a bump in that place
on a sidenote( would like to hear from pros not speculating pease)
is there an optimal v stack inlet shape? and length maybe? cone/round/with sharper angle at certain part etc
I do appreciate the work and research here but this setup is being dyno'd nearly 2 years later. It's hard to compare the dyno numbers. Also, the stock itr dyno was in December.
Edit. Take back my previous opinion after seeing the opened runner entries on a monitor as apposed to iphone.
I am aware that this is unfortunately 2 years down the road. We just had a cold front roll through the other day and conditions were almost exact today! 6whp and 2ft lbs for all we know could be a valve adjustment or some other small variable, however we expected results like MikeySpec did years ago. In his setup/testing, the Performer X made 15whp and 6ft lbs MORE than a stock ITR manifold. With gains like that, we expected any number above the previous dyno.
honda did put together a pretty good motor in the ITR.... not a huge surprise to me there wasnt much gain.
Keen to see someone do the same with the s2 ultra street - I was going to but elected to do cams etc first as its a proven power maker.
Yeah unfortunately it seems like the power I originally made was about as good as it would ever get with stock internals. The car drives phenomenal and that's what is important. It chirps 4th gear on 280 tread wear 205 tires lol, but we will let a trap speed do the talking.
