Need Help: Temp gauge reads warm even before I crank the engine
Old Jun 18, 2014 | 12:49 PM
TiMiD703's Avatar
Default Need Help: Temp gauge reads warm even before I crank the engine
1995 Honda Civic EX 4 Door Automatic
Every morning before I head to work and the temp is below cold as it should be. I put the key to the II position and the temp jumps to 25%. I crank the car and it starts just fine but still stays in the 25% position. I drive for approx. 5 minutes and it reads normal temp (a little under 50%).
When I unplug the temp sensor (one wire) from under the distributor it drops below cold and reads the same temp (48%) when I put it back in.
Upper and lower radiator hoses get hot after normal operating temps so I am assuming the thermostat is okay.
Just found out the radiator fan does not kick on. Jumping the plug so the fan is always on untill I figure out what it could be.
Old Jun 18, 2014 | 01:05 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Need Help: Temp gauge reads warm even before I crank the engine
The sensor for your gauge cluster is a one-pin plug under the distributor. Unplug it. Does the needle still go to ~25% on cold start?
Old Jun 18, 2014 | 05:40 PM
slomofo's Avatar
GDD Member
What is the outside air temperature when you start your car in the morning?
Old Jun 18, 2014 | 05:54 PM
Former User's Avatar
Are you suggesting the OP lives on Mercury?
Old Jun 18, 2014 | 06:06 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
I would bet these have the same issues as my 98 lx, temp gauge was crazy, would show the engine was overheated within a minute, but if you popped the hood, you could put your hand on the engine, it wasnt the sensor, as I changed it, I did note that none of the aftermarket senders matched Hondas spec, not even close, How long have you owned the car? it's possible someone installed the wrong sender. The only thing I could possibly figure out, was the wiring diagram for the cluster showed a voltage regular built into the circuit board. If it was failing it could cause erratic gauge readings, I never did figure it out as the transmission failed, and I ended up selling the POS. Check your sender against spec with an ohmmeter and if it's good, you might want to swap out the cluster
Old Jun 18, 2014 | 06:07 PM
NotARaCist's Avatar
Yeah, for it to be around 25% at start-up, the engine would have to have an ambient temperature of something like 150*F. Getting the block to that temperature without turning it on would take...well, maybe not Mercury, but at least Venus
Old Jun 18, 2014 | 06:09 PM
they've been hitting 117 in parts of Cali, friend says it's hell on earth
Old Jun 18, 2014 | 07:30 PM
NotARaCist's Avatar
117 < 150.
Old Jun 18, 2014 | 08:09 PM
slomofo's Avatar
GDD Member
I don't know what 25% is in regards to temperature but I thought the halfway mark was around 200.
100 degrees doesn't seem too difficult to achieve on a hot Phoenix day.
Old Jun 18, 2014 | 09:15 PM
NotARaCist's Avatar
The halfway mark is something around 200, but it isn't linear - the bottom mark isn't 0. Realistically, the bottom mark is more like 100.
Old Jun 18, 2014 | 09:51 PM
shotoutacc0rd's Avatar
You guys are saying OP needs one of these?
http://s1372.photobucket.com/user/fa...80bf2.jpg.html
[IMG][/IMG]
I would guess its a harness problem.
Old Jun 19, 2014 | 03:27 AM
Also could be a bad wire or temp gauge.
Old Jun 19, 2014 | 03:44 AM
Maybe he can do that trick you guys always do to diagnose these sorta things.
take the voltage at the sensor side of the wire and the dash harness side to see if things are short circuiting. Its something along those lines. I hate doing electro al diagnoses personally, I just wanted to contribute because I had the sensor laying around lol
Old Jun 19, 2014 | 04:53 AM
When my Civic engines are fully warmed up, the cluster temp gauge reads approximately 1/3 of the way to Hot, and the engine temp is about 196F.
Old Jun 19, 2014 | 06:35 AM
tony_2018's Avatar
Fish Twig
Sensor probably fudged, unplug sensor and see if it still gauge still shows it being warmed.
Old Jun 19, 2014 | 06:36 AM
tony_2018's Avatar
Fish Twig
Why not suggest how to do it?
Old Jun 19, 2014 | 12:35 PM
I hate diagnosing electrical problems I dont know how yo do it right. Plus I have no idea what any of the values should actually be or where to properly check the electrical value
Old Jun 19, 2014 | 12:38 PM
Unplugging the sending unit to see whether the temp gauge needle now stays at Cold is the place to start with this problem, as NotARacist pointed out already.
Old Jun 19, 2014 | 12:46 PM
I think he said that he did that, "unplugged the 1 pin sensor under the distributor and it says cold".
that rules out the rest of the system and points to the sensor I guess? These lil guys suck
Old Jun 19, 2014 | 12:48 PM
You are correct. I missed that info in the first post.
The sensor is indeed the problem.
Old Jun 19, 2014 | 01:13 PM
make sure you get a OEM one, I have never been able to find one that has the correct ohm range aftermarket, I tried every auto parts store there was, every sender read out of factory specs
Old Jun 19, 2014 | 01:50 PM
And be careful with the sucker! They're pretty darn fragile.
Old Jun 20, 2014 | 11:19 AM
slomofo's Avatar
GDD Member
Your civic must have a problem then because the gauge in my Corsica has numbers on it and the halfway mark reads 210.
Old Jun 20, 2014 | 11:22 AM
It's just differences between the scales of the gauges.
Old Jun 20, 2014 | 01:07 PM
NotARaCist's Avatar
Also, Chevy != Honda.
