rpm question
Old Jun 18, 2014 | 09:17 AM
Hughie1987's Avatar
Default rpm question
Where my rpm needle is showing is my car at idle at a light, I have some kinda electrical issue with my car as u can see by the temp gauge so Im wondering if thats also causing my rpm gauge to show pretty much nothing until I press the gas pedal
[IMG][/IMG]
Old Jun 18, 2014 | 05:22 PM
fcm's Avatar
fcm
Old Fart
Default Re: rpm question
If car is running OK and RPMs increase smoothly as you step on the gas the problem is most likely lust a needle adjustment, pull needle off and install in the correct position.
If on the other hand car is not running smoothly the problem is most likley the ICM is on it's way west, or connections to it are poor.
The tech is "controled" by the ICM so you can also just try and tighten the connections, [unplug, carefully "crip" terminal tighter and reconnect]. 94
Old Jun 18, 2014 | 08:51 PM
Hughie1987's Avatar
thanks dude
OhMyTofu
Audio / Security / Video
Oct 17, 2009 08:12 PM
jdmstreethatch
Oct 25, 2006 01:26 PM
eg92b16a2
Nov 29, 2004 09:50 AM
xcivicdx
Feb 23, 2004 04:25 PM
