NJ SOLD
I have owned this car for over 2 yrs now and unfortunately it's time for her to go to a new home. My fiancée & I are getting married in Sept. & moving back to North Carolina shortly after. We don't need (4) cars between the 2 of us, haha.
ASKING $4,699 OR BEST OFFER!!
VIN # 1HGCD713XRA003998
As the title says this is a 1994 Honda Accord Coupe LX. Body currently has 153,XXX miles on it & the motor has around 35-40k.
The paint is very similar to the factory Bordeaux Red Pearl but the previous owner had the car repainted about 5 yrs ago with House of Kolors Burgundy paint (Custom paint formula). The paint is in great condition (could use a good buff), however there is a small rust spot on the right rear quarter panel (has not come through the paint yet). And last fall I had a lady tap the back left quarter/bumper, little to no damage. I will show pictures of both spots.
Car was tuned last January by Chris Harris @ Xenocron Tuning Solutions in North Jersey on their Mainline Dyno. Chris is an awesome dude & very well known in the Honda community for his tuning ability. I knew Chris previously as I took EFI 101 & EFI Advanced classes at his shop. Car put down 212whp & 145wtq. Dyno sheet will be posted below.
SPECS;
Engine/Performance
JDM H22 (35-40k Miles)
JDM BB6 Intake Painted Wrinkle Black
K&M Drop-In Filter (10k miles)
AEM Power Steering Pulley
Deka Mini Battery w/ Custom Battery Tray (10k miles)
NGK ZFR6FIX-11 Plugs (10k miles)
NGK Wires (10k miles)
Accel Ignition Coil (10k miles)
OEM Cap, Rotor & Gasket (10k miles)
OEM Wrinkle Black Valve Cover
C&R Visteon Racing Radiator
Skunk 2 Radiator Cap (10k miles)
Upper Stainless Steel Radiator Mounting Hardware
Stainless Steel Fender washers/rivets
Xenocron Chipped ECU
LSD Racing Stage 2 clutch/12lb Flywheel
New Clutch Slave Cylinder (2k Miles)
New Clutch Master Cylinder (2k Miles)
Mishimoto Racing Low Temperature Thermostat
Walbro 255LPH Fuel Pump
Skunk2 Titanium Competition Series Adjustable Cams
Skunk2 Intake Manifold
Skunk2 Pro Series Valves
Blox type-B cams
Blox Dual Valve Springs
Blox Titanium retainers
Blox 68mm Throttle Body
Blox VTEC Solenoid Cover
Blox Cam Seals
Blox Drain Bolt Set
Tri-Y Header Coated Black
AEM Fuel Pressure Regulator
AEM Fuel Rail
AEM Fuel Filter
Trubendz 2.5” Custom Exhaust (10k miles)
12” Vibrant Resonator (10k miles)
18” Magnaflow Resonator (10k miles)
2.5” Vibrant Stealth Black Muffler (Single Exit) (10k miles)
RC 550cc Peak and Hold Injectors
Energy Suspension Poly Front Motor Mount Insert (10k miles)
New OEM Style Front Motor Mount (10k miles)
Mishimoto Coolant Overflow Tank (10k miles)
New OEM style Rubber Exhaust Hangers (10k miles)
1 OEM Style Torque Solutions Poly Exhaust Hanger (10k miles)
NTK 24042 Front 02 Sensor (10k miles)
“New” Duralast Starter (10k miles)
New OEM Coil Cap (10k miles)
New DriveRite Alternator/AC Belt (500 miles)
Exterior
House of Kolors Burgundy paint (4 yr old/Custom paint formula)
Body Color painted CF Hood
Mugen Front Upper Grill
OEM Style Front Lip (6k miles)
Matte Black Sprayed Side Moldings & front/rear lips
3BSpec 4300k HID Kit for Low Beams
JDM OEM Fog Lights
3000k VVME HID Kit in OEM fogs (H3c)
JDM Power Folding Mirrors
Good Condition Used Rear Side Marker Lights
Good Condition Used OEM Style Gas Cap
6th Gen. Windshield Washer Nozzles (10k miles)
New Washer Hose from Tank to Nozzles (10k miles)
Konig Feather 16 x 7” Rims w/ Yokohama S-drive 205/50/16 tires (10k miles)
Interior
OEM fog light switch in factory location
Auto Door Locking mechanism (Connected to the brake pedal)
Alpine CDA 9886
Sueded Headliner (Needs to be redone, extra fabric will come with car)
OEM Rear Seat Painted Black
Acura CL Lower Door Panels w/ Leather Insert
Acura CL Gauge Cluster
Honda Accord Upper Door Panel w/ Locking Mechanism & switch
Acura RSX Leather Driver & Passenger seats
MOMO Tuner Steering wheel
NRG Short Hub
NRG Quick Release 2.0 Hub
JTC Customs 94’-97’ Short Shifter (10k miles)
JTC Universal Shifter Base Bushings (10k miles)
CorSport Shift Linkage Bushings (10k miles)
“New” Black Interior carpet
Under-carpet insulation (FatMat brand liquid and Mat)
Lightning Customs Black leather with red stitching shift boot
Blox 5spd Weighted Gunmetal shift ****
Viper 500 Alarm
Good Condition Used JDM Side Mirror Switch
Good Condition Used JDM Side Mirror Relay
Good Condition Used OEM Master Window Switch
Good Condition Used Front Center Console Section Painted Black w/ Shifter Bezel
Good Condition Used Rear Center Console section w/ Cup Holder & Arm Rest Painted Black
Good Condition Used Coin Tray for Knee Panel Painted Black
Good Condition Used Knee Panel Painted Black
Good Condition Used Rear B & C Combo Panels Painted Black
Good Condition Used Ashtray
Good Condition Used Trunk Spare Tire Cover
Good Condition Used Rear Speak Deck/Shelf with Speaker Covers Painted Black
Good Condition Used Door Jam/Sill Panels
Good Condition Used A Pillars Painted Black
Good Condition Used Floor Fuse Box Cover
Good Condition Used Trunk/Gas Door Covers
94’ Prelude Si E-brake Handle
OEM Honda Cargo/Trunk Mat
Hexo Fitted Floor Mat Set
Brakes/Suspension
Eibach Sportline lowering springs
KYB AGX adjustable dampers
DC Sport Front upper strut bar
DC Sport Rear lower strut bar
AeroSpeed Rear Upper strut bar
Acura CL Rear Disc Brake Conversion
Suspension Techniques Front & Rear Sway Bars
Prothane Front Sway Bar Bushings & Brackets (2k miles)
Megan Racing Rear Camber Arms
Megan Racing Rear Toe Arms
Megan Racing Rear Control Arms
ROH Conversion w/ Brand New Pair of OEM Acura CL Wheel Bearings/Hubs (10k miles)
Adaptive One, Dual Ceramic Front Brake Pads (Napa) (10k miles)
Pair of EBC USR Slotted Rotors (10k miles)
New Axle Nuts (10k miles)
(8) New Rotor Screws (10k miles)
Apex Stainless Steel brake lines (With ATE Dot4 fluid)
Brand New OEM style Front Upper Control Arms (500 Miles)
Good Condition Used Front Lower Control Arms
Good Condition Used Radius Rods
PROS:
• 25.8MPG average over the past (36) tanks of gas. This is all around town driving, 15 miles to work & back. Would easily get 30MPG+ on the highway.
• 93 Octane used only!
• The car is in very good shape and is well maintained.
• Clean Title in hand.
• I am the Third Owner of the vehicle.
• Oil is changed every 2800-3000 miles using 5W-20 Castrol & an OEM S2000 Oil Filter.
• Motor only has 35-40k miles on it. All gaskets and seals and belts were replaced when the motor was swapped in.
• The motor runs perfectly with no issues & has NEVER burned any fluids, oil, coolant, etc.
• Compression test a little over a year ago, 220 across the board!!
• I have full maintenance & parts purchase records since I've been the owner.
• Paint is in great condition besides spots mentioned & seen in pics.
• Air Conditioning works great, COLD!
• Dash is perfect with no cracks.
• All stereo components work properly.
• Car has been garage kept for the past year+.
• Car will come with extra parts!!
• Probably more to add to this list but that is all I can think of for now...
CONS:
• Head Liner needs to be redone, will come with extra fabric.
• Some small interior panels need to finish being painted.
• Slip Fit Header has a minor exhaust leak. I’m only able to smell it while sitting at a traffic light.
• Reverse Light on the driver’s side rear works when it wants. (If you play with/move around the tail light wiring it comes on. Been like this since I bought the car, 2+ yrs.)
• High Beam Light on the driver’s side works when it wants. (If you play with/move around the head light wiring it comes on. Just started happening a couple months ago.)
• October last year a lady hit me on the driver’s side rear bumper. Rear Bumper tab is broken but can be repaired. Bumper sags slightly. I have before & after pics of the “accident”.
• Right rear quarter panel has a minor rust spot, has not come through the paint yet.
• Car is 20 yrs old, could replace some bushings/ball joints, etc to improve ride quality.
• Non-LSD Transmission, fairly easy swap for the new owner.
I spent A LOT of time over the past 2 yrs cleaning this car up as I did not like/agree with a lot of the things the previous owner did. I can provide the previous owner's For Sale thread if you would like to compare.
Car will be posted for sale on here, Honda-Tech.com, CD5tuner.com & Craigslist.
I have 220+ pictures of the car in my photobucket if a buyer is interested in checking them out.
I spent around 7 hrs detailing the car the past couple nights. Please see the below pictures, if you need any other pictures let me know!
SPECS;
Engine/Performance
Blox type-B cams
Blox Cam Seals
Blox Drain Bolt Set
AEM Fuel Rail
AEM Fuel Filter
Exterior
JDM OEM Fog Lights
Interior
Alpine CDA 9886
NRG Short Hub
Viper 500 Alarm
Brakes/Suspension
PROS:
CONS:
Even though this car only puts down 212whp, it holds it's own against newer cars with a bit more power. I put 1-2 car lengths on a 2012 STi from a 1st gear roll. I put 2-3 car lengths on a bolt-on 2004 SRT-4 from a 2nd gear roll. And it stayed dead even with a 2004 Audi S4 from a 2nd gear roll.....Not too bad for a 20 yr old car!
ALL PMs & emails replied to!! First potential buyer coming to look at the car tonight or tomorrow AM!!
Please see here: http://hondamarketplace.com/announcement.php?f=59&a=44
