HELP!! 95 HONDA WONT GO 4000 RPMS
Old Jun 18, 2014 | 01:12 AM
ray2raw's Avatar
Icon2 HELP!! 95 HONDA WONT GO 4000 RPMS
I have 95 honda accord vtec and it wont let me pass 4000 rpms. once i hit 4k it just kicks me back down to 3.5 and i dont know why. I have a new distributor cap, starter, spark plugs and good oil. I need help!
Old Jun 18, 2014 | 08:42 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: HELP!! 95 HONDA WONT GO 4000 RPMS
Hey man, probably want to try the technical forums. This section is for appearance modification.
Try https://honda-tech.com/forums/forumdisplay.php?f=2 or searching for others that have already got an answer https://honda-tech.com/search.php
Edit: Quick search, same issue - https://honda-tech.com/forums/showth...highlight=rpms
Old Jun 19, 2014 | 01:22 AM
holmesnmanny's Avatar
Check for any and all codes. If no codes possibly a clogged cat could be the cause.
Old Jun 19, 2014 | 01:42 PM
MAD_MIKE's Avatar
MM Gruppe B
Got VTEC? Check your oil level. If it is too low the VTEC oil pressure switch will not be activated. The engine will not be able to rev.
Old Jun 19, 2014 | 07:27 PM
jollyhonda's Avatar
Any check engine light? Could be going into limp home.
Old Jul 2, 2014 | 09:45 AM
ray2raw's Avatar
I wrote a post here not long ago.
I'm having a lil problem with my 95 Honda Accord 2.2L Vtec and i need help. My starter recently went out so i put a new one in an it started my car good only the problem is now it wont let me go to 4k rpms. Once i pass 3.5k and goes into 4k it bogs down a bit and kicks me back down to 3.5k I dont know the cause of the problem i checked everything and it seems to be good. My CEL is on only because i hit a squirrel and my sensor went out but other than that i dont know what it might be i just put in new spark plugs as well.
Old Jul 2, 2014 | 11:40 AM
How many replies is it gonna take before you start diagnosing the issue ?
letxmexbethe1xo
Jan 26, 2012 03:07 PM
Major90
Dec 18, 2009 07:36 AM
slammedaccord329
Jan 4, 2008 03:21 PM
gauto5150
Jan 4, 2007 04:22 PM
prop329
May 31, 2004 12:27 AM
