98 b18c1 swap into my 95 integra
Old Jun 17, 2014 | 02:25 PM
StevenW's Avatar
Default 98 b18c1 swap into my 95 integra
Hey everyone, im not to sure what to do, I have a 95 ls integra and want to swap a 98 b18c1 engine into it. Im not to sure what ecu i should get for it, i know the 98's are obd2 and my 95 integra is obd1. should i get a p72 obd2 ecu then just get a wiring convertion kit. any ideas and help you have would be greatly appreciated, Thanks
Old Jun 17, 2014 | 03:42 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: 98 b18c1 swap into my 95 integra
No. There are no wiring changes. You should rewire your home computer so that it can access google search, though.
Use your OBD1 injectors and distributor. Plug in your wiring harness. Plug in your ECU.
Enjoy.
Old Jun 17, 2014 | 06:23 PM
B_Swapped93's Avatar
just fine a obd1 p72 as for VTEC... rywire sells a "VTEC wiring kit" just swap over your obd1 injectors grab a obd2 to obd1 dizzy harness(rywire) and for the alt use your old one with the round plug. the rest is plug n play.
Old Jun 17, 2014 | 09:07 PM
B serious's Avatar
Ah. I must have missed the part about him having a LS.
VTEC, IAB, and knock can be wired in via a subharness. Pin the subharness into your ECU plugs. Plug in a OBD1 P72 ECU.
Old Jun 17, 2014 | 10:11 PM
StevenW's Avatar
Alright thanks a lot
Old Jun 18, 2014 | 05:59 PM
HondaPartsHero's Avatar
Technical Hero
-wire in VTEC, knock and IAB
-reuse your alternator and injectors
-you'll need a conversion harness to use the distributor
-if your engine is not JDM you'll have some extra sensors you don't need, Evap purge on the intake manifold and the CKF by the crank pulley
GSR_ITR_BOIB
Apr 7, 2018 02:52 AM
GreatWave
Dec 28, 2016 06:53 AM
JustAskMe
Aug 19, 2010 10:47 AM
ITR1071
May 20, 2002 03:56 PM
