00 SiR - B16a2 Rear Motor Mount Question
I have a 2000 SiR with the stock B16a2 in it. The rear motor mount by the transmission under the intake manifold went. I have hansport mounts but the previous owner put them in. I was just wondering would this be the correct thing to buy as a replacement part?
http://passwordjdm.com/Hasport-Bille...P2735C812.aspx
If not what would be?
Thanks
Thanks
I've already tried to get pictures its a weird spot, basically the mounts inside rubber is being beat out it looks. There is a big pile of rubber laying around the mount and the way my car shakes whenever i let off the gas is making me assume thats the reason.
Could be. How do the other mounts look, including the 2 front ones?
I will go make sure I did now, if it is just the mount I mentioned would buying that part I said in the first choice be the right thing to do?
http://hasport.com/store/index.php/egrr.html
And you have to specify the hardness.
Same part. Straight from Hasport.
Brandon H.
Aug 14, 2011 06:57 PM
onyx00
Sep 24, 2004 01:00 PM
