AC condenser fan fuse keeps blowing
It may be the AC condenser fan motor or the wiring shorted.
Unplug the connector to the AC condenser fan. If the fuse doesn't blow anymore, it probably is the motor. On the motor side connector, you can check for continuity between the motor's Blu/Blk wire and body ground. Blu/Blk wire is a blue wire with a blk stripe running through it. If there is continuity to ground on the Blu/Blk wire, you probably have a short in the motor.
DaX
21
May 23, 2019 09:27 AM
ek9_B18C
Oct 6, 2012 02:59 PM
orangeracer
Jun 28, 2008 09:01 AM
FLCivic
Dec 18, 2007 04:37 PM
