Darton dry sleeves + 84,85,86mm Piston
Old Jun 17, 2014 | 09:53 AM
1HGEJ2's Avatar
Default Darton dry sleeves + 84,85,86mm Piston
Hello
Can i use darton dry sleeve (dds) for na with big pistons?
Benson used the original aluminium case for there sleeves. The different is the benson sleeves have a full iron flange on the top. in the marktplace is a 86mm dds engine for sale.
Old Jun 30, 2014 | 05:15 PM
OMG's Avatar
OMG
Default Re: Darton dry sleeves + 84,85,86mm Piston
what is the OD of the dry sleeves
Old Jun 30, 2014 | 05:54 PM
GhostAccord's Avatar
Darton also has dry iron liners (sleeves) with or without a flange. You should find out what liners where installed and then check Dartons website for bore specs!
Old Jul 1, 2014 | 12:55 AM
1HGEJ2's Avatar
88mm
Darton sell them only to replace. But dartons are stronger.
I think i go wet and be safe.
Old Jul 1, 2014 | 04:48 AM
Can't beat the Darton M.I.D sleeves. Liners are for wimps!
Old Jul 1, 2014 | 08:55 AM
OMG's Avatar
OMG
at 88mm OD, the thickness of the sleeve walls would be
2mm thick for 84mm (88 OD = 84 cyl ID + 2mm +2mm)
1.5mm for 85mm
1mm for 86mm
Old Jul 2, 2014 | 01:30 PM
1HGEJ2's Avatar
86mm dry sleeve are other sleeve. it called 86mm drag sleeve. darton drag sleeve 86mm (only for drag)
zongetsu
Jul 30, 2012 04:12 PM
Steeve_Civic
Apr 11, 2012 06:43 PM
H22Luda720
Mar 20, 2006 01:33 PM
H22Luda720
Mar 20, 2006 05:35 AM
Daniel26
Oct 17, 2004 10:01 AM
