****98 Spec ITR Cluster, CTR Armrest, CTR emblem..ETC****
I'm located in Los Angeles, CA.. you can best reach me through text 786-444-9341
JDM ITR 98 Spec Cluster with black housing. Everything works fine, and lights up amber, The speedometer is going to have to be recalibrated, which is very simple to do when driving (Just pop the needle out, and insert at correct speed when moving, done). Everything else has been untouched. $80 +shipping.
OEM JDM Civic Type R 96-00 rear hatch emblem. Very clean, no fading on the red, and the rear pegs are still intact. $55 picked up
USDM Civic SI steering wheel with airbag, and all plastics! This steering wheels looks like the Type R version because of the sticker overlay on the factory airbag emblem (I don't remember where I bought the overlay, so please don't ask.) The only issue with the it is the ware on top of the steering wheel, but other than that it's a very clean piece!
$150 picked up
USDM Integra Type R shift boot. It doesn't have the red stitching like the JDM one, but it's still very clean. $25 picked up.
$125 picked up
OEM JDM Civic Type R Stanley sidemarkers, used but clean $20
Broadway 270mm Flat (nonConvex)Blue tined mirror. $10 picked up.
$150 picked up
$125 picked up
If your Integra is 1997 and below, just swap out the green piece on your existing cluster and just slap it on the 98 spec cluster. That should make it work fine.
