no spark on 96 vtec prelude
Old Jun 16, 2014 | 07:48 PM
riddick5's Avatar
Default no spark on 96 vtec prelude
Soooooo i need some help HT. im stuck. ive checked about as much as i can figure out to check and now im running out of easily accesible things. I was adjusting my valves, and grounded out the alternator while removing the harness. This blew the 100amp fusible link so when i was done with the valves and buttoned up i went to start it and no power. i replaced it and the car would crank but no spark. theres def fuel being injected, i smell it as soon as i start cranking. the fuel pump primes, the CEL comes on and goes out as per usual. IVe checked for codes currently and there is none, although through out the process of testing stuff i have had a few. Ive tested the ignitor and coil by grounding out the ICM wire and the coil discharges so that complete circuit from the ecu to the coil is good. I think i either fried my ecu, or fried a circuit in my engine harness. ive checked everything i can think of, read a bunchb of guides on troubleshooting ignition system, im down to a new wireharness or ecu, unless anyone has any great ideas. Thanks.
Old Jun 17, 2014 | 03:56 AM
pentaq's Avatar
Default Re: no spark on 96 vtec prelude
I'd say replace coil anyway. It always goes bad.
Old Jun 17, 2014 | 03:12 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Check all the fuses....
Old Jun 17, 2014 | 10:03 PM
holmesnmanny's Avatar
Check all engine bay fuses, especially the 15a ecu fuse. Then check for actual spark.
scobaru
11
Oct 24, 2016 06:44 PM
Tad
Dec 30, 2012 03:04 AM
cardudelude
May 2, 2010 01:11 PM
xSoylentGreenx
Jul 2, 2008 12:10 PM
Skip
10
Jan 29, 2004 07:42 PM
