Brakes
Old Jun 16, 2014 | 07:48 PM
RACETEGGY's Avatar
Default Brakes
I have a 90 da that had a sticking caliper on the passenger side. It locks up if I barely touch the brakes. I replaced calipers and rotors and pads. It pulls so hard to the right that I can't drive it. The abs light is on so I'm wondering if I remove the abs controller and just run new lines if it will resolve my issue. I get plenty of fluid to the caliper so I know it has th do with the abs. Thanks in advance guys.
Old Jun 16, 2014 | 07:49 PM
evilclown312's Avatar
Default Re: Brakes
The rubber hose that runs to the caliper.
Old Jun 16, 2014 | 08:04 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Brakes
Caliper is probably locked up due to bad slide pins, bad installation, or a bad caliper or a bad e brake mechanism.
Check all those things.
Old Jun 16, 2014 | 08:12 PM
RACETEGGY's Avatar
Default Re: Brakes
I have a new front calipers rotors pads and hoses. New guide pins and hardware. I replaced it all thinking I had a bad caliper and it didn't help at all. I know it has something to do with the abs
Old Jun 17, 2014 | 05:16 AM
TheRealTegger's Avatar
Default Re: Brakes
Your problem is unlikely to have to do with the ALB (official name). The ALB used on the DA/DB is of the "pass-through" type: it is completely inactive until called upon.
More likely something is not installed correctly, or is of poor quality. Have you replaced or removed the master cylinder, at any point?
Old Jun 17, 2014 | 05:17 AM
B serious's Avatar
Default Re: Brakes
Unplug the ABS fuse. See if it stays locked.
Old Jun 18, 2014 | 05:21 PM
RACETEGGY's Avatar
Default Re: Brakes
I haven't touched the master cylinder.
Old Jun 18, 2014 | 06:07 PM
RACETEGGY's Avatar
Default Re: Brakes
after the new parts it stopped till 5-6 stops after driving a bit
Old Jul 8, 2014 | 03:36 AM
RACETEGGY's Avatar
Default Re: Brakes
got it fixed. abs controller was bad.
Eric Buschman
Honda CR-V & Element
Jun 1, 2013 10:01 AM
NVturbo
May 27, 2008 12:53 PM
AK_20_EM1
Feb 1, 2007 08:15 AM
kit50si
13
Nov 18, 2006 06:06 AM
