97 Accord - Which Color Wires for Backup Camera?
Old Jun 16, 2014 | 07:34 PM
dhabell's Avatar
Default 97 Accord - Which Color Wires for Backup Camera?
I just installed a backup camera in my trunk key hole in my 4 door Special Edition. The power wires are short. I have it hooked up wrong. Now it's going to the wires in the lights that are on the lid, but the reverse camera only comes on when I put it in R when the lights are on. W hitch color wires do I use and where are they?
Old Jun 16, 2014 | 09:42 PM
spoonhatchback2001's Avatar
Default Re: 97 Accord - Which Color Wires for Backup Camera?
I am guessing you want to know the color of the reverse lights? If so it's only 2 wires. A power and a ground. So one wire going to be black that should be the ground and yeah that only leaves the other wire which is Green.
Old Jun 17, 2014 | 07:49 AM
dhabell's Avatar
Yeah. That's what I did. Black for ground and green with red stripe and silver squares for positive but yet it only works with the parking lights on. Is it BC I used the wires from the small white square in the light on the trunk lid instead of the white square on the quarter panel ?
Old Jun 17, 2014 | 01:19 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The circuit diagram for the back-up lights show Grn/Blk as the power (+) wire. Grn/Blk is a green colored wire with a black stripe.
The grn/blk is at various locations: 8P gray connector at left side of trunk area (SE); 2P gray connectors on either side of trunk lid; 6P blue connector for trailer lighting at left rear trunk.
Old Jun 18, 2014 | 02:26 PM
dhabell's Avatar
thanks guys. Yeah I had the wrong wire. I had the power wire hooked into a red one. When I hooked it into the green and black ones it works.
efjones9
11
Jun 12, 2009 07:25 AM
CapnKrunch
12
Mar 9, 2007 09:45 AM
Racermech
May 23, 2005 08:29 AM
HONDA-2NR
Dec 24, 2003 08:04 PM
LSRydeR
May 15, 2003 09:38 PM
