90's honda ICM(igniter) cross compatability ?
Old Jun 16, 2014 | 06:27 PM
B_Swapped93's Avatar
Default 90's honda ICM(igniter) cross compatability ?
cliffs: swapped no-name dizzy ICM into OEM dizzy with failing ICM, thing were fine for a week...I did have to transfer the heat sink could this have been my issue ?. the things spazing out again
2nd what are my options as far as igniters go Honda wants $266 not including our 13% cdn sales tax basically $300, which is tempting BUT steep right now I just burned threw $600 tires in under 2000 km's BFG rivals are **** if any ones wants to know.
next I'm assuming the non-vtec b series ones will work 94-01 will the d-series one work ? thinking about going to a junk yard and grabbing a whole bunch if they're there.
Old Jun 17, 2014 | 11:16 AM
Default Re: 90's honda ICM(igniter) cross compatability ?
Pls help! this is a stupid issue to have.... not about to take the plunge on the Hondata COP-R
Old Jun 17, 2014 | 12:08 PM
tamboo's Avatar
10 Year Member
airtex or beck seems to be the part of choice.
you can put in diff make/model/year and see if the part
numbers match up.
http://www.rockauto.com/catalog/x,ca...,parttype,7172
Old Jun 17, 2014 | 06:26 PM
I'd need the last one shown the oem one mounts differently then the OE-Replacement ones(see my DIY), I'm just hesitant seeing as I fired one in a weeks time not even. part number as usually a good way but I've got different number to fit then matched ones, afaik the D/B/H ones are all the same OEM at least.
david6969
Mar 10, 2016 10:32 AM
HondaPartWorld
Oct 12, 2012 09:45 AM
MadCoder
May 18, 2012 05:28 PM
Silvertc
Aug 21, 2010 12:08 PM
dennis278
Mar 27, 2006 07:58 AM
