b20 ticking noise HELP
I have a problem with my jdm hi-comp b20 i want to see if someone can give me a lil help. I got it from hmotorsonline since I've had it I only put 120 miles ..Its making a ticking noise I cant seem to figure out what's causing it. To me its sounds like it coming from the manifold/ fuel rail area.. I took a video to see what you guys think. Link below
setup
jdm high comp b20
walbro 255 fuel pump
skunk2 manifold with hondata gasket
Stock Ls fuel rail and fpr
type-r throttle body with p2r gasket
3 inch short ram intake
Plm (rmf) headers
2 1/4 piping with no cat and a ws2
chipped LS ecu with b20 basemap
setup
jdm high comp b20
Plm (rmf) headers
the videos are private so i cant see them.
did you check the valve lash? the b20's specs are tighter than the vtec's.
also, ive seen more than a few of them have a little tick or clack to them from that area. most often it goes away once warmed up might just be the rocker arms warming up and coming into spec
My thoughts are it's one of two things... valve lash or loud injectors. I've heard some nasty injectors over the years and it's amazing how much noise they can make.
If you don't have any fancy way of listening to the motor (diagnosis microphones, stethescope) you can use a long pry bar or screwdriver. Touch the pry bar to the part of the motor you suspect is making noise and put your ear directly on the end of the handle. The sound will travel right up the handle and you'll hear it perfectly.
