97 Civic - axle probs after hitting pothole
Old Jun 16, 2014 | 10:04 AM
nuber1zero's Avatar
Default 97 Civic - axle probs after hitting pothole
so yesterday i broke an axle. hit a pot hole go figure but anyways i got a new one and put it in made sure it was all the way in and the joint wasnt seperated before finishing up. when i set the car on the ground and tried to leave the joint close to the trans spereates and spins.
bad part or bent/broken suspension component what do you guys think
Old Jun 16, 2014 | 11:38 AM
Former User's Avatar
Default Re: axle probs
Car information and many pictures are required.
Old Jun 16, 2014 | 12:42 PM
nuber1zero's Avatar
97 honda civic dx no anti lock brakes. dont have a lift just a jack so pictures are probably going to be butt
Old Jun 16, 2014 | 12:46 PM
Do you expect members to throw out random guesses because you don't want to post pictures?
Old Jun 16, 2014 | 12:51 PM
shotoutacc0rd's Avatar
Default Re: 97 Civic - axle probs after hitting pothole
Put a 4x4 on the jack to make it higher? Use jack stands if you're smart..
Old Jun 16, 2014 | 01:12 PM
veks's Avatar
Grab a few lights, pull it up a curb, take a few pics.
So you changed an axel with just a jack and no jack stands? Wow you like living on the edge.
Old Jun 16, 2014 | 02:56 PM
nuber1zero's Avatar
its been raining a while so pics wont happen today but yeah i did it with no jack stands takes about ten minutes so i yeah
Old Jun 16, 2014 | 10:53 PM
Koko4's Avatar
Out of curiosity..how did you do that? I'm genuinely intrigued.
Also, make sure the axle is completely seated into the transmission...easy potential fix.
Old Jun 19, 2014 | 06:10 PM
nuber1zero's Avatar
so the craziest thing happend.. the bolts got ripped out the trans mount and cause all this crap to happen fix it tho
Old Jun 19, 2014 | 07:30 PM
B_Swapped93's Avatar
not a surprise, those bolts are known to strip over time I had to time-sert mine on my integra.
GuiGJ
Jul 28, 2009 09:14 AM
exsquid
May 3, 2008 10:23 AM
cab525
Jun 7, 2004 10:00 AM
antiabercrombie
11
Mar 25, 2003 06:37 PM
