Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Engine misfire and CEL
Old Jun 16, 2014 | 10:03 AM
martin.willmott's Avatar
Default Engine misfire and CEL
2003 Honda civic 1.6 flashing cel, lumpy idle.
Replaced the engine after a major cambelt failure, misfire and flashing cel, replaced so far:
Cambelt
Tensioner
water pump
Crank sensor
Cam sensor
Head gasket
4 coil packs
4 spark plugs
4 injectors
common rail
air intake temp sensor
knock sensor
vtec oil pressure sensor & solenoid, complete housing
Checked,
leak down test all green
chemical coolant gas test, no exhaust gas present
Timing checked a dozen times
injector signal present,
no air leaks,
valves all good and set correctly
Currently I can sit and rev the nuts off it but as soon as I try to drive it away, it sounds rough and cel starts flashing.
I am now at my wits end and considering writing it off.
Codes, sometimes misfire on cylinder 2, sometimes cylinder 4, or any random misfire.
Old Jun 17, 2014 | 03:35 AM
Default Re: Engine misfire and CEL
After 2 months and throwing £600 at it I'm phoning the customer to say, come and collect it, no charge, I give up!
glenners
May 20, 2016 05:44 AM
ramboPandA
Nov 27, 2014 12:09 PM
preludeSRV
Feb 28, 2008 08:56 PM
92HB_HB
Feb 21, 2005 03:59 AM
Krayzielix
Sep 6, 2003 11:37 PM
