Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Brakes, Struts, finally found the squeak
Old Jun 16, 2014 | 04:07 AM
solex's Avatar
Default Brakes, Struts, finally found the squeak
I just finished replacing all of the brakes, rotors and drums all around.
Stock rear drums and pads, with Brembo Rotors and stop tech pads, VHT paint on the Calipers
I had previously installed Koni Yellows at all four corners with Eibach springs, in addition to Russell SS braided and silicone coated lines.
During the front brake installation I found the source of the squeak that I have had for over a year. The retaining clip used to hold the flexible and hard line in place is simply a e-clip and provides no tension on the lines to keep them from moving in the body mounted retainer. I greased it up to prove it and it worked, now back to Majestic for the original clips.
I beaded in the brakes and the whole system is really much better than the tired system I replaced.
Next on the to-do list is to replace the lower control arm bushings in the front with Moog replacements. I particularly interested in how the the compliance bushing will feel since it is not a stock replacement but one with an actual spherical bearing. Will post pictures.
BETOSCOUPE
Acura TL, RL & ZDX
25
Feb 10, 2012 04:53 PM
spoonhatchblack
Suspension & Brakes
Feb 13, 2008 03:19 PM
M4
May 30, 2005 09:01 PM
XyKo
Feb 8, 2005 02:52 PM
ninor
Acura TSX
12
Jan 17, 2005 08:24 AM
