civic springs in integra????
Old Oct 30, 2002 | 06:20 PM
1hotintegra's Avatar
Default civic springs in integra????
my friend has an h&r racedrop in his 97 civic , could i put them in my 94 integra???
Old Oct 30, 2002 | 06:21 PM
vtecdc2's Avatar
Default Re: civic springs in integra???? (1hotintegra)
not sure about 97's, but i know that 92-95 civic springs will fit 94-01 tegs
Old Oct 30, 2002 | 06:26 PM
tilt's Avatar
Default Re: civic springs in integra???? (VTECDC2)
they will probably fit... it's more of a question of how much will it drop the front and back and how well will they perform.
Old Oct 30, 2002 | 07:41 PM
racermike27's Avatar
Default Re: civic springs in integra???? (tilt)
They will fit no prob. But the question is do the springs use the same spring rate as those set out for the integra, cuz if they dont your car will handle sloppy as well as having a different ride height than specified. I know that when you put integra springs in a civic the civic is lower than the height specified for the integra. so mayeb the civic spirngs in the teg might not drop the car as low, but maybe the spring rate is softer and might make up for it. I woul worry about the spring rate tho you dont want to put something in that will make the car handle sloppy.
Old Oct 31, 2002 | 10:28 AM
JakeB.'s Avatar
Photography Pundit
Default Re: civic springs in integra???? (racermike27)
I have a pro-kit from my old Civic on my teg. The springs felt just fine for first two years but now my struts are starting to go so thet're not so fun anymo'.
[QUOTE]... having a different ride height than specified. QUOTE]
My teg is definately lower in the front than my Civic was, but I think it looks pretty good (since the Civic was higher in the front than in the back).
[Modified by MugenB18, 7:36 PM 10/31/2002]
[Modified by MugenB18, 7:39 PM 10/31/2002]
Old Oct 31, 2002 | 01:37 PM
threatcon13's Avatar
New User
You have a fully built motor with turbo kit and 130 shot and don't use a standalone? also phantom grip?
Dav94Lx
Suspension & Brakes
Aug 4, 2007 02:12 PM
IntegraJCEN
Suspension & Brakes
10
Mar 17, 2006 10:26 AM
SICKSOLSI
Jun 29, 2004 01:14 AM
stehigs321
Dec 9, 2002 07:43 PM
LS AnGeL
Oct 14, 2002 02:24 AM
