Honda CR-V & Element 2WD & 4WD Element & CR-V
Engine stuttering.. need help!! see pic
Old Jun 15, 2014 | 04:29 PM
FATKID87's Avatar
Default Engine stuttering.. Distributor $800?!
so i while i was driving the other day my car started to stutter at highway speeds... thought i had some bad gas so i got some fuel cleaner and replaced my fuel filter as a precaution.. it went away... 2 weeks later it came back with a fury MORE STUTTERING at all speeds and then went to start it and nothing... after a couple of days of sitting there it starts and runs fine again....
Anyways after i start looking around i found that my fuel pressure sensor has some cracked hoses and a t fitting that isn't attached to anything looked it up and i don't know where this hose goes anyone know? should it even have the t? is it just a breather hose?
Old Jun 16, 2014 | 03:56 AM
dogbiscuit's Avatar
Default Re: Engine stuttering.. need help!! see pic
no check engine lights?
Old Jun 16, 2014 | 07:05 AM
FATKID87's Avatar
nope
Old Jun 17, 2014 | 05:53 PM
Vyyarm's Avatar
Could possibly be the PGM-FI relay. I've seen where the solder on the contacts get loose and cause similar issues. Another thing to check is to see if your getting good spark. You might have a weak ignition coil, or maybe bad contacts on the distributor cap. Fairly easy to check. First take off the ignition wire off a spark plug and ground it into a screwdriver, it should jump about half an inch and be a nice blue color. If not then id pop off the distributor cap and see how it looks, if there is too much corrosion on the contacts I would do a tune-up. I cant think of any way off the top of my head to check a coil without a scope other than checking resistance with a DVOM, but that test doesn't check the coil when it has a load on it so its not really an accurate way to test it unless its completely shot. Lastly an upstream oxygen sensor could sometimes cause an issue similar to that. The most simple way to check it without reading the values with a scanner or DVOM is to disconnect the plug and see if your problem goes away, if it does then that's your problem. But I would definetly start with checking for weak spark. Good Luck.
Old Jun 24, 2014 | 10:09 AM
FATKID87's Avatar
ok so i couldn't figure it out... took it to the mechanic and they wanna charge me 800 dollars for a distributor change...Thats outragous right? I might be wrong but that is 3 bolts pull out and slap the new one in right? or is there more to this that i don't know?
Old Nov 9, 2014 | 05:51 PM
EJ8CIVIC's Avatar
http://owners.honda.com/
Make an account and type in ur vin see any recalls pop up.. I had 2 recall
el_espiritu
Oct 17, 2012 07:06 AM
blk_eg4
Aug 3, 2006 08:27 PM
hack3r
Apr 1, 2004 07:02 PM
tnord
22
Sep 26, 2003 08:45 PM
Quetzolcotl
16
May 19, 2002 04:43 PM
