'01 accord ex/v6 code
....I'm working around a previous post that I lost...sorry.
My issue is the P0301 code for cyl#1 which names a culprit (misfire-monitor), reset, could not test run more than 1 run...Please advise.
Thanks ahead for any response.
hondoman1
hondoman1
So your code says you have miss fire cylinder #1. I would suspect a poor spark plug or a failing coil pack. I would pull the #1 spark plug and swap it with another cylinder and then also swap the #1 coil with another that isnt the same cylinder as the spark plug swap and see if the miss fire moves. then you will know if its the plug or coil or something else.
jaxx4k
Dec 6, 2004 07:25 PM
revvin9k
Nov 8, 2004 04:25 AM
brcivic411
Dec 8, 2003 08:55 PM
