B18CR INCREASING COMPRESSION RATIO
Old Jun 15, 2014 | 12:34 PM
xkhalil333x's Avatar
Default B18CR INCREASING COMPRESSION RATIO
Hello,
I was wondering if anyone has any thoughts or ideas on how much power can be gained by increasing the stock cr of 11.0:1 to say 12.5:1 using the stock bore. Is this something worth doing in which a lot of power can be made? for a fully bolted on motor on pump gas vs the same setup but with 12.5:1 cr what would be the hp difference/gain roughly? thanks in advance
Old Jun 15, 2014 | 12:41 PM
1991_crxsi's Avatar
Default Re: B18CR INCREASING COMPRESSION RATIO
All other things equal and stock cams, about a 3%-5% overall WHP gain.
Old Jun 15, 2014 | 01:55 PM
F22Master's Avatar
Unless you already have the engine apart to rebuild it, it would not be worth it. Even then, 12.5:1 is a little on the high side. 11:1 is plenty for pretty much any setup. I would spend my time elsewhere. Porting, cams/valvetrain, header, ported IM, etc.
Old Jun 15, 2014 | 02:27 PM
centraldriver29's Avatar
Cam upgrade will be a must for noticeable gains tho.
Old Jun 15, 2014 | 07:20 PM
Miguel613ekb18c's Avatar
You can dump all the money you want with very little return in hp no need for cams and pnp
Just go boost
Old Jun 16, 2014 | 01:18 AM
Just go boost
thanks for all your replies. i already have a built and boosted one. i want an all motor build that can get me in the high 12s with slicks
Old Jun 16, 2014 | 09:49 AM
1991_crxsi's Avatar
Just a suggestion, you can sell your B series and get and H23A blue top and go H2B. Stock block with I/H/E will get you in the 12s if you have the right chassis and tires.
If you aren't willing to part with the B series I understand, but really that H2B set-up is going to be a much better bang for the buck. My CRX with full interior runs high 12s with just regular street tires and a less that great driver (me). This is just a suggestion, but if you decide to go this route I doubt you will be disappointed.
Old Jun 21, 2014 | 12:57 AM
OMG's Avatar
OMG
Don't run 12.5CR with stock cams, unless you have 100+ octane
Old Jun 21, 2014 | 01:57 AM
Black R's Avatar
25 Year Member
Done people claim 10whp per point in compression raised...
azn99si530
Mar 29, 2007 07:10 PM
EITCP
Mar 18, 2007 04:07 PM
precisionelite
Jan 11, 2006 11:06 AM
LU
Mar 18, 2005 02:39 AM
CPR
Jun 29, 2001 07:31 AM
