89 Civic - transmission and suspension questions
Old Jun 14, 2014 | 09:14 PM
tadams31's Avatar
Default 89 Civic - transmission and suspension questions
I'm new to the Honda world and I have a 1989 Honda Civic DX hatchback I'm just trying to make it a clean simple Street cruiser I just need help on what's best to do to my vehicle to get it to where I wanted to be.
first thing I'm trying to do is a transmission swap from a four-speed to a 5 speed what are the best transmissions I could use for my car that can Bolt straight up?
second thing I'm trying to do is give it a clean Low Stance what is needed to give it a low aggressive look?
those are things I'm trying to do now if anybody can help me please respond back.
Old Jun 14, 2014 | 09:25 PM
spoolymcgee's Avatar
Default Re: Need guidance please!!!
d series lsd tranny would be the best any d series transmisson would work. Do research on suspension find witch one you like, and read reviews. What is your budget?
Old Jun 14, 2014 | 09:33 PM
24TEN's Avatar
PHANTOM MENACE
More specifically an 88-91 D-Series transmission is what you want because it uses a cable actuated clutch like your car is set up for. Generally speaking the higher the trim level the transmission is originally from the better. There is a difference on spline count on 88 models so be weary (I'll leave you with that to search for on your own).
Old Jun 16, 2014 | 06:04 PM
Former User's Avatar
Default Re: 89 Civic - transmission and suspension questions
See the forum Rules sticky. Thread titles must summarize the tech question/problem. Title edited.
Old Jun 17, 2014 | 04:56 AM
Freemananana's Avatar
I'd get an 89-91 Si Trans, wouldn't worry about LSD really since I don't think that's where you should spend your money.
Suspension is always going to be Koni/GC as far as HondaTech is concerned.
I'm still a Progressive suspension fanboy. The drop springs would do you good. You could probably upgrade the stock struts while you are at it. If you just want a decent ride and a lowered look, springs and struts will be enough.
Ruben Sanchez
Suspension & Brakes
Oct 13, 2018 09:20 PM
eric587
Suspension & Brakes
Mar 18, 2012 12:25 PM
allEKs
Feb 10, 2008 05:54 AM
Diplomat1929
Jun 3, 2006 12:56 PM
