FS Only 94 Acura Integra GSR with Type R motor
Old Jun 13, 2014 | 05:25 PM
guyver13's Avatar
Default FS Only 94 Acura Integra GSR with Type R motor
Clean Title 3rd owner
Original Odometer: 200k miles
Engine: JDM B18C (Type R) 80k miles
Transmission: ITR w/ LSD (J4D)
Exterior: Original OEM Black Paint (could use a paint job)
Interior: Black leather interior with Type R Door Panels
Price: $5000 with rims 4500 without (no rush to sell and no joy rides unless cash in hand)
Smog: Just smogged on 4/2/2014
Contact: Call or Text me (818)536-8267
NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES
Motor is healthy and Working AC(Blows F*in Cold!!!), Power Steering, Cruise Control
Only major con is the dent somebody hit on my driver door, but that can be fixed with some type r doors
Recent Maintenance:
-New Upper Rad Hose
-New Thermostat
-New Timing Belt
-New Water pump
-New NGK Spark Plugs
-New NGK Spark Plug Wires
-New Distributor Cap and Rotor
-New Oxygen Sensor
-Valve Adjustment
-New Gaskets (Intake Manifold, Exhaust Manifold, Oil Pan, Valve Cover, VTEC Solenoid)
-New TPS Sensor
-IACV Cleaning
-New Vacuum tubes
-New ECT Sensor
-New Tie Rods
-Alignment
-New Axles
-New Engine Mounts
-Ignition Timing at 16 degrees BTDC
-New Clutch, Slave, and Brake Master Cylinder
-Stainless Steel Braklines
-New Rotors
-New Akebono Brake Pads
NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES
Upgrades:
-JDM B18C engine
-JDM P73 obd2a
-Rywire obd1->obd2a harness
-JDM 4-1 Headers w/ Heat Shield
-JDM 2.25inch Catalytic Converter
-Mugen Twinloop Catback Exhaust
-Work Equip 01's
-ITR Strut bar
-Koni Yellow Struts
-Ground Control Eibach Springs (615f/525r)
-Ground Control Extended Top Hats
-Skunk2 Front Upper Control Arms
-Buddy Club Rear Camber Arms
-Skunk2 Rear Lower Control Arms
-ASR 24mm Sway Bar
-ASR Subframe
-Spoon Lower Tie Bar
-Skunk2 Short Shifter
-ITR Shift ****
-ITR Shift Boot
-98-01 JDM Tail lights
NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES
NO TRADES
unless you want to trade for an Acura TL or TSX 06+ with less than 70k clean and no problems AND cash on your side
Old Jun 13, 2014 | 08:03 PM
em1loc's Avatar
Default Re: FS Only 94 Acura Integra GSR with Type R motor
Bump
Old Jun 14, 2014 | 10:31 AM
2000FBPITR's Avatar
glws
John_Lim
Mar 24, 2010 03:26 PM
Peruviann83
Jan 3, 2009 01:18 AM
Peruviann83
Apr 24, 2008 08:38 PM
IntegraDriver
Nov 15, 2006 05:49 PM
spooncivic1
Feb 14, 2006 09:27 AM
