Spoon springs --- w/ Koni yellow
Old Oct 30, 2002 | 05:46 PM
EleanoR's Avatar
Default Spoon springs --- w/ Koni yellow
I installed these a couple of days ago. I got to thinking about it. The rears came with new bumpstops (the non externally adjustable ones) and i used the new ones. The fronts did not so i re-used the stock bumpstops from the stock damper. I was reading around and some people had mentioned that it is a good idea to cut the bumpstops a little for more suspension travel. Is this the case for me? If the answer is yet i can take them out again (i have access to power tools) and re-do the job and cut the front bumstops a little. Shed all the light on the subject as possible
Old Oct 30, 2002 | 05:58 PM
George H's Avatar
Default Re: Spoon springs --- w/ Koni yellow (EleanoR)
When I bought eibach prokits for my gsr, a paper came with the springs explaining how much to cut the bumpstop for my application. Did you recieve any such instructions with your springs?
BTW, it is a good idea to cut the bumpstops because you dont want to be bouncing off them all day long.
Old Oct 30, 2002 | 06:00 PM
EleanoR's Avatar
Default Re: Spoon springs --- w/ Koni yellow (KANJI)
The instructions that came with the Koni shocks absolutely SUCKED. Their pictures were horrible and there were no directions really to read from. Mostly pictures and they were horrible like i said. Oh well i guess you get that kind of thing when you pay $500+ for a set of adjustable shocks.
Old Oct 30, 2002 | 06:55 PM
1GreyTeg's Avatar
IM George Knighton, he has your EXACT setup and had some minor issues when he had them installed.
A.
wildRHDeg6
Apr 30, 2009 08:59 PM
ES2
Suspension & Brakes
Oct 10, 2006 03:17 PM
jermyzy
Apr 24, 2004 11:06 PM
AllMotorITR
Mar 26, 2002 01:00 PM
