if i unbolt the master cylinder
Do i have to bleed my brakes?
I need to take out my alternator, no clearance at all in any angle to remove from bottom, so the mc might be my best option, other than removing the manifold.
Only need to bleed if you open the hydraulic fluid lines.
If you are just unblolting from the brake boosterish you do not need to bleed anything.
theres space to pull out over the axle. you just have to unbolt the bottom bracket.
if you have a swap, then maybe you dont have space.
if you have some coilover that limits the droop, just unbolt the bottom bolt of the shock fork.
I always remove mine from the bottom by removing the lower alt bracket just as tyson posted. And im b16 swapped 90 lx sedan, and b16 swapped 91 crx si.
Idk but my alternator does not clear from the bottom, the axle gets in the way. I ended up unbolting the mc, but also had to remove the fuel rail for extra clearance.
If a D15B2, alternator is removed through wheel well. Remove wheel, remove mud flap in wheel well. Disconnect alternator, drop to bottom, go to wheel well and grab alternator and remove through hole.
legendaryr56
Aug 12, 2006 08:07 AM
HU MAN CHU
May 7, 2006 09:53 PM
