twm itb or skunk2 ultra street
Old Jun 11, 2014 | 03:27 PM
kulo's Avatar
Default twm itb or skunk2 ultra street
torn between the 2
i have b18cr with bolt ons
maybe cams in future
Old Jun 11, 2014 | 07:32 PM
viperjng's Avatar
Default Re: twm itb or skunk2 ultra street
Hi,
Chk these 2 threads of mine may help in making a decision. I had OBX ITBS 1st and the switched to Skunk2 Ultra street. All the info with pics and dyno are there.
My advise is the Ultra Street for the long run. Itbs have their share of pros and cons.
1> Not the easiest to tune for daily driving
2> Really loud
3> Peppy but loose out in the top end
4> Decreased brake efficiency as you share the vaccum lines from the brake with the itbs unless you do some mods for vaccum.
The car is a 1995 Civic EG with a B18C5 engine overbored and built.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/2-0l-type-r-itb%92s-india-dyno-included-3107591/
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/2-0l-na-build-skunk2-ultra-street-manifold-dd-tech-cams-3143704/
Jignesh
Old Jun 11, 2014 | 07:43 PM
FlewByU352's Avatar
Neither IMO. If you can't afford Kinsler's you do a proper manifold. The Ultra Street on a 1.8L only makes peak power and basically sucks under 8,000RPM.
Old Jun 11, 2014 | 10:09 PM
blacK_Dc4's Avatar
I agree. though TWMs and OBXs are alot cheaper than Kinslers', they are still $500+. better money spent elsewhere. the stock ITR manifold performs well with a bigger throttle body.
the Ultra street lost hp for me everywhere in the lows and mids as stated. I would disagree with the fact that it's for peak power, because it didnt even carry power for me past 8700rpm. pretty disappointed. the Race version has shown way better results, though it's overkill in your setup. I would invest in some cams before IM.
Old Jun 12, 2014 | 01:31 AM
kulo's Avatar
yeah i have pro series intake manifold on right now and stock itr tb
i have alpha s 70mm to fit
or get maxbore.com to match my itr tb to 70mm tapered to 65mm at the plate
Decatur Racer
May 26, 2016 02:30 PM
jimmyjun0213
11
Mar 19, 2015 09:46 PM
kulo
Jun 13, 2014 01:14 PM
Leo's 07 Honda Civic Si
Honda Civic (2006 - 2015)
33
Sep 11, 2009 12:48 AM
thegsrman
Jun 12, 2004 12:36 PM
