Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
MY FG1 COOLING FANS DOESN´T START
Old Jun 11, 2014 | 10:37 AM
emilio2488's Avatar
Default MY FG1 COOLING FANS DOESN´T START
2 weeks ago i have a crash...the radiator and condensator was badly damaged in the crash.
I buyed a new radiator and the 2 fans, i connected them and start the engine...the check engine light doesn´t appeared...i let the car going to operative temperature but the fans doesnt start.
Old Jun 11, 2014 | 11:01 AM
DaveSi677's Avatar
Default Re: MY FG1 COOLING FANS DOESN´T START
Was the cap off when you were doing this?
If the cap was off it take a longer time for it to reach normal temperature.
Also try making the car run and put the fan to the max on hot. See if the fan kicks in.
If that doesn't work check the voltage it should be at 12v. If it's not you might have to change the fuse. Swap the fuse out and check to see if the fan kicks in.
Keep us posted.
Old Jun 11, 2014 | 12:48 PM
emilio2488's Avatar
Well the cap was On when i start the engine
I dont moved the car because im waiting for a new transmission cooler, i do the test with the car parked.
When yo talk about voltage is the battery voltage or the voltage in the plug connector of the fan?...i checked in the fuse box and i dont see broken fuses
Old Jun 11, 2014 | 08:04 PM
DaveSi677's Avatar
voltage of the connector of the fan
Old Jun 13, 2014 | 06:30 AM
emilio2488's Avatar
i checked the fan conector voltage and mark 0.00 to 0.01...maybe is a relay?
E JAY 1
Mar 5, 2008 09:17 PM
g0tgot
Apr 29, 2007 02:41 PM
ecksman
Mar 4, 2007 11:39 AM
khg186
Jun 9, 2005 03:15 PM
Answer
Aug 9, 2001 10:21 AM
