im back
everythings al hooked up now exhuast headers shift linkage battery ground on thermostat and one from tranny to frame battery is good and had it on crank assist have oil in it new filter primed it before trying to crank it over got gas got coolant new spark plugs coolant got fuel pressure hear the fuel pump coming on and it was leakin out my fuel rail so i had to change the o ring on the end of it the other day the timing is good cause we checked it again yesterday gettin spark cause we took out the plug and tried crankin it and could see it arching and i have the msd blaster coil got two ecus tried my other ls ecu just for hahas have compression across the board no blown fuses checked all of them sprayed starter fluid in intake just to try and help it start nothin spraued some in the clyinder still nothin no check engine light only two connectors unplugged one for evab and other one look like vechile speed sensor connector map and tps i dont think are mixed up cause it only stretches so far
gonna try and flip the inside of the dizzy around just to see if maybe that could be it adjust the disbutor alitle bit after top dead center i kno it gotta be like 18 degrees if not mistaken cant think of anything we havent checked yet
Last edited by Former User; Jun 11, 2014 at 11:50 AM. Reason: Pic with finger gesture deleted
You're in a shop and you guys can't get it running? You checked timing and it's good but you're not sure if it's "gotta be like 18 degrees"? The color of the spark was what? Are you throwing any CELs?
stumped so far did what we thought it could possibley be,no check engine light timing is good we did it again yesterday just to be sure,i kno its supposed to be advanced alittle
Pull that aftermarket coil stuff off of it and return the setup to vanilla and get it running BEFORE you start adding all the aftermarket stuff to it.
What's even IN the block/head?
b18 b1 rebuilt new block clean and honed integra type r piston on ls rods acl main rod bearings gsr oil pump arp rod bolts apr flywheel bolts arp head studs stage 2 6 puck clutch jdm gsr tranny blox high compression valves dual valve springs ti retainers supertech valve lock keeper brian crower stage 2 403 cams adjustable cam gears blox intake manifold 70mm tb fuel rail pressure regualtor msd blaster coil chiped p75 od1 ecu
So what color was that spark? Was the timing verified? And tell me again, because I'm not going to read, is it a no crank or crank but no start? Injectors getting fuel?
and this guy said make anew thread so i said ok i will fine just to make yall happy and im workin on it did everythin could possibley check so far so ifyour gonna bitch and conplain you can go somehwere
put new plugs in it the injectors worked last time im sure the order of them being plugged in doesnt matter does it? nd we spray fluid in the clyinder to see if it did anything
And you don't answer my questions. Does it start up with a stock ECU? Doesn't matter if everything worked the last time. It aint working now. Your ****-poor attitude and refusal to answer questions last time caused your thread to become totally convoluted. You're doing it all over again.
