b17 distributor problem in b16 head, crower cams
Old Jun 10, 2014 | 01:35 PM
sirtef9's Avatar
Default b17 distributor problem in b16 head, crower cams
When I install the 3 distributor bolts it binds up the intake cam. If I install 1 bolt its ok. Never seen this issue.
Distributor only goes in one way and goes in easy.
Any ideas?
Thanks
Old Jun 10, 2014 | 04:45 PM
sirtef9's Avatar
Default Re: b17 distributor problem in b16 head, crower cams
Can this get moved to technical?
Old Jun 11, 2014 | 07:09 PM
civic-steve-94's Avatar
I know the gsr distributors are physically larger then b16 so maybe that's it. Its not to noticeable until you set the side by side.
Old Jun 14, 2014 | 07:57 AM
sirtef9's Avatar
The b17 sits different against the head, was binding up my cam. Swapped in a b16 distributor problem solved.
Eydreeyun
Northern California (Sales)
May 6, 2009 07:37 PM
ls97vtec
Jun 10, 2007 09:59 PM
Rob Dizzle
Oct 10, 2003 03:48 PM
