P0420 Code Freeze Frame
Old Jun 10, 2014 | 12:45 PM
dcleach070667's Avatar
Default P0420 Code Freeze Frame
Hi all My name is Dave, I live in Manchester ,United Kingdom. I own a Honda Civic 1.6 Vtec 2003.I joined to see if other Honda users could help me out with a problem i have. Last year the matrix(sounded like a box off ball-bearings) went in my catalytic converter. I had an after market React one installed by a Garage. Almost instantly the EML came on. went back to garage immediately and was told I would have to live with it, apparently it is part and parcel of installing an after market part.
My Honda Civic went in for an MOT on Saturday and failed on high emissions for the first time ever, was the Same garage, they said the Catalytic converter wont be responsible for the high emissions despite a P0420 bank 1 code. They want me to go to a fuel injector specialist off theirs. I am not convinced this garage actually knows what it is doing. They also said both O2 sensors are also working correctly. I have pulled an FF of the code being activated to see if any off the lads and ladies on here can put me on the right path and least expensive. I will be eternally grateful if I can rectify this problem without unnecessarily replacing parts given my financial situation
Thanking you all very much in anticipation off your responses.
FF P0420
Fuel Sys 1 CL
Fuel Sys2 0
Calc Load 42.74%
Coolant Temp 84.0C
STFT B1 5.46%
LTFT B1 10.15%
M.A.P 43Kpa
Eng Speed 2286.68Rpm
Veh Speed 60/km/h
I.A.T 32.0C
TPS 15.29%
mas21958
Honda CR-V & Element
Jun 13, 2019 07:41 AM
bEnJiX
Honda Civic (2006 - 2015)
16
Mar 29, 2014 08:45 PM
Felipe 40
Jan 8, 2013 11:58 AM
