auto to manual swap, accord chassis prelude transmission question
Old Jun 9, 2014 | 05:18 PM
Jcd5's Avatar
Default auto to manual swap, accord chassis prelude transmission question
when doing the swap, i noticed a couple extra lines the automatic didnt have, and i don't believe the f22 trans has either. the trans is a m2s4
what are the 2 capped lines? do they serve and purpose to me or leave them capped?
and what is this large uncapped line? above where the shift cables attach?
Old Jun 9, 2014 | 07:45 PM
holmesnmanny's Avatar
Default Re: auto to manual swap, accord chassis prelude transmission question
The top pic is the speed sensor with steering assist lines. If your car doesn't have steering assist then you don't need to worry about it.
The bottom pic is the transmission vent. It needs to have a breather cap on it. It helps prevent moisture from getting inside which can wreak havoc on the internals of a transmission but allows air to vent out of it at high speeds.
Old Jun 9, 2014 | 08:06 PM
Jcd5's Avatar
My car has power steering, it just doesnt run through the transmission. the speed sensor will work without fluid though i assume.
And 1 more question, do i need to attach the trans cooler lines to the manual? i dont see anywhere to attach them
kyosuke714
Mar 3, 2016 12:43 PM
hon2984
Mar 9, 2014 06:49 AM
h23bb1
Feb 28, 2012 11:20 AM
uberEFtuner
Mar 21, 2010 07:27 AM
Subwarrior
Aug 18, 2004 07:17 AM
