Where can I buy this part? auto trans to radiator piece
Old Jun 9, 2014 | 02:07 PM
WagonTales's Avatar
Default Where can I buy this part? auto trans to radiator piece
This is the piece that comes with a radiator, and connects a hose from the auto transmission to the bottom of the radiator. Not sure what it's called, but I need to find one!
I bought a radiator because this piece was leaking on mine. I thought the whole thing was pre-installed on the radiator and I would just clamp the hose onto it. But I found these pieces loose, so I just used the part I needed. Now I wanna get my $90 back from AutoZone
94 Accord wagon LX if that helps
Thanks in advance!
Old Jun 9, 2014 | 02:50 PM
NerfGunner420's Avatar
Default Re: Where can I buy this part? auto trans to radiator piece
$90? autozone? lmao what a joke, return it, go to star auto parts, for me its cheaper there never ever had a problem its better to go oem ill tell you this now cb7's don't like after market radiators unless they are full aluminum
Old Jun 9, 2014 | 05:30 PM
WagonTales's Avatar
Think Star Auto has the part I was asking about?
Can you pick it up and mail it to me?
Old Jun 9, 2014 | 07:28 PM
holmesnmanny's Avatar
You bought a radiator for a manual car. Take it back and get the radiator for an auto. It's weird cause normally radiators tend to come fitted for either the manual or the auto and it just has a plastic cap around it for manual cars that don't need auto fluid coolers.
Also, a lot of times you can simply tighten that copper colored washer/nut in your above pic and it will seal it. It's important when you get a radiator to tighten that up before you install it.
Old Jun 10, 2014 | 07:46 AM
WagonTales's Avatar
No, I got the right radiator. I just took that piece and used it on my old radiator because that was the only part I needed. I just want to replace that piece and put in in the box so I can return the radiator.
Old Jun 11, 2014 | 12:01 PM
94 accord typeR's Avatar
junkyard or buy a whole complete radiator
Bush-15
May 26, 2009 09:43 AM
Razr2
11
Jan 14, 2008 08:21 AM
aeon
May 23, 2005 12:35 PM
SamC
May 18, 2005 05:51 PM
GKIN
Aug 21, 2004 05:32 AM
