What causes to black out inside of the IM? na b20v
Old Jun 9, 2014 | 10:38 AM
centraldriver29's Avatar
Default Can someone explain the intake reversion better than google???
As title stated, can anyone explain to me what are the primary causes of intake reversion? I know its normal to have some for extend but does it directly reflect the health of the motor? My IM is pretty black inside, need your advise and explanation what might be happening and solution!
Old Jun 15, 2014 | 06:09 AM
GhostAccord's Avatar
Default Re: What causes to black out inside of the IM? na b20v
The black inside your intake manifold is most likely due to the Exhaust Gas Recirculation (EGR) system and/or oil vapors passing through the Positive Crankcase Ventilation (PCV) system.
Old Jun 19, 2014 | 07:33 PM
Ya but b-series doesnt have true egr, and i dont have pcv system through intake. I just run catch can. Where is this coming from? My exhaust isnt flowing good enough???
Old Jun 20, 2014 | 09:54 AM
OMG's Avatar
OMG
50% correct
keep researching
Old Jun 20, 2014 | 12:10 PM
I came to conclusion that my exhaust isnt flowing good enough and too much of compression for the small of cams isnt really helping neither. Ill upgrade the exhaust to 3inch all the way to muffler and trying to source skunk2 tuner2 and try actual degreeing this time. Hopefully solves this issue.....
Old Jun 30, 2014 | 05:05 PM
OMG's Avatar
OMG
reversion or reverse flow occurs because a pressure differential exist--most times briefly
actually, all flow occurs of a pressure differential--flow is flow regardless of direction
there are a couple things that can be done or designed to reduce reversion
good work, keep up your good research
Old Sep 14, 2014 | 06:48 PM
Thanks man
M Allen Duncan
11
Mar 21, 2018 05:52 PM
Atomic1
Apr 6, 2010 06:28 AM
The G2 Racer
Aug 26, 2008 06:40 PM
turboman
Aug 22, 2006 12:38 PM
Fatty_1775
Aug 15, 2003 05:52 PM
